I have just gone through the nozzle tuning program with Airflow Performance and although I need one more flight to verify, I think I am within about .3 gph for all peaks. The funny thing is that when I get more than about 20 to 30 degrees LOP the temps begin to rise! Ron at Airflow explained the reason-- the cumbustion event is happening slow enough that it is still happening when the exhaust valve opens, thus higher temps--but it is unsettling to see the temps going up when it seems like they should continue going down. Maybe I should be using the absolute value away from last to peak, the combination of down and then back up? Does anyone else have this happen?
FG
Looks good to me Web.
The test I referred to is simple. Give it a try and see where you are at, if nothing else you have an excuse to fly again!
Here is the test from Airflow Performance.
Nozzle Tuning Data
The basis of nozzle tuning is to get each of the cylinder EGT?s to peak at the same fuel flow. Your aircraft must be equipped with EGT information on each cylinder and fuel flow information. A digital flow meter is preferred.
To gather correct data for nozzle tuning, set a cruise power setting. Typically 24? MAP and 2400 RPM. Set the mixture to be 0.5 GPH richer than peak on any cylinder. At this setting record all the EGT?s for each cylinder. Lean the mixture 0.2 GPH and record all the EGT?s again. Lean the mixture an additional 0.2 GPH; record all the EGT?s again. Continue leaning the mixture 0.2 GPH and record the EGT?s until all the cylinders have peaked.
An alternative method although not as accurate is to lean each cylinder to peak and record the fuel flow at that point. You will get the same data, but since the EGT reacts slower than the leaning process you may go past the peak and not know it. This is especially true if an engine monitoring lean find function is used. We get more accurate data taking the EGT data manually. If you use an automatic data acquisition function, allow 30 seconds or so at each fuel flow setting so the EGT value can stable out.
After the data is taken, we determine which nozzles to change to get all the cylinders to peak at the same time. You will notice that the EGT number at peak may not be the same for each cylinder, THIS IS NOT IMPORTANT. The cylinders that peak first (higher fuel flow) are the lean ones; the cylinders that peak last (lower fuel flow) are the rich ones.
Getting all cylinders to peak within 0.2 GPH is ideal.
..... I would really like to be confident in the calculated HP figures when I operate LOP. ........
Fin
9A
........... Then, whether ROP or LOP if you have the same IAS, you have the same power output.
Correct, but you won't have the same fuel flow. At ROP you will be using more fuel for the same power. How can this be
When ROP, some of the fuel is unburned, and acts to cool the engine, and therefore is "wasted".
It's really hard to compare "apples to apples". Sometimes those wretched "oranges" get in the way.![]()
Interesting observation. I'm certainly not going to say you didn't see what you saw, because you were there and I wasn't. But, it is hard to reconcile your observations against theory. Do you recall the range of altitudes you would have been at when you made these observations? Do you recall roughly how repeatable the IAS was for a given percent power?I don't have a fuel flow gauge on my airplane. However, back in the early 90s I did some very careful observation of indicated airspeed verses power settings in my Mooney. I didn't use the Mooney power schedule, I used the Lycoming schedule which was very detailed in terms of RPM, MP, and air temperature.
What I found was that within very small variation, if I had the same power setting I had the same IAS. This was independent of OAT, RPM, and altitude.
How accurate is this method? I'm sure there are inaccuracies because I can think of some potential problems right up front. Nevertheless, I thinks its close enough to address this subject.
Altitude TAS CAS
(ft) (kt) (kt)
4000 167.5 158.0
6000 170.6 156.2
8000 173.7 154.3
10000 176.9 152.5
Interesting observation...... Do you recall the range of altitudes you would have been at when you made these observations? Do you recall roughly how repeatable the IAS was for a given percent power?
Accepted theory says that profile drag is proportional to the square of the equivalent airspeed. ...... So, roughly speaking, profile drag is proportional to IAS^2.
Engine power times prop efficiency = drag times TAS.....
All true, except you need to replace IAS with TAS. If you have a given amount of drag, the power required is equal to TAS times drag (with appropriate unit conversions). So, power required varies with TAS times drag, with drag varying with IAS^2, so power varies with TAS * IAS^2. But, the relationship between TAS and IAS varies with altitude, so in theory, the IAS we get for any given power should also vary with altitude.I agree drag is roughly proportional to IAS^2. So, if you have the same IAS, you have the same drag. Therefore, the same work is being done. Thus you are at the same power setting. I think this makes the point.
The point was that from an aerodynamic point of view, it is thrust power that matters. Thrust power is the power that is actually transmitted by the prop to the airflow. It is equal to engine power times propeller efficiency. Prop efficiency will be relatively constant over the range of normal cruise conditions, so we can ignore it. But if we starting making big changes in altitude, power, rpm, etc, then the prop efficiency will be changing, and this will affect any predictions we attempt to make.you lost me in this: engine power x prop efficiency = drag x TAS
........ So, power required varies with TAS times drag, with drag varying with IAS^2, so power varies with TAS * IAS^2. .........
As you note, there are other factors that come into play. Weight and CG for example. At a given weight and power, you'll go slightly faster at aft CG than you would at forward CG. I suspect the difference is on the order of 2 kt over the full CG range. Weight - my model suggests that at 75% power at 8000 ft the IAS would increase about 1 kt for every 100 lb reduction in weight. At lower power cruise and higher altitudes, the effect of weight will be slightly greater, as the power required vs speed curve gets flatter as you more closer to IAS for minimum power.Anyway, back to finding power when LOP
All of the information needed is in TAS, IAS, and the ROP power schedule, but drag does not exactly follow IAS^2 due to AOA. How significant is this?
The few knot IAS difference I get in my airplane going from full fuel to very low fuel on a long trip say it might be significant. The 1 mph difference between light and heavy on the vans web site say not so much. This may be another case of faulty observations.
We can come up with all kinds of nice theoretical relationships between speed and power, but I'm not sure they are usable in the real world in the way you want. I.e., I don't think it is practical to say "if you want 75% power, set the power to get a speed of XXX kt IAS". First, even at a given altitude, the relationship between speed and power is affected by weight, CG and temperature, with each of those possibly affecting things by a couple of knots. Second, it takes quite some time after setting power for the speed to stabilize. Third, the air is never perfectly calm. Even on the nicest of days, there will be small perturbations that cause the airspeed to wander up and down a few knots.I seems like mapping IAS^2 x TAS against the ROP power schedule should yield a solution in which given IAS^2 x TAS power is always known regardless of mixture setting. That is, at least over the relatively narrow range of normal cruise speeds. At much lower speeds the power is so low it doesn't matter how you lean and at much higher speed you should not be running LOP.
Please comment.
This may work for a 4 cylinder, but it doesn't work for a 6.
The old Lycoming info I have certainly suggests that 14.9 X FF = HP when LOP isn't too far off the mark. The exact answer you get from this old Lycoming analysis technique varies a bit depending on rpm, compression ratio, power setting, and how far LOP you are, but usual results seem to be in the range of 14.5 X FF to 14.7 X FF. But, given typical accuracy of FF indications, there is nothing wrong with rounding up to 15.As others have posted, I am not sure why you are seeing anything different. This formula is not cylinder specific - its piston engine physics. Air and Fuel mixtures burn well in a range that is well understood in piston engines and it doesn't change. The actual formula is 14.9 X FF = HP when LOP. I use 15 because it gets me within 1 or 2 HP on my IO-550 - which is close enough for me.
Fuel Pwr Pwr bSFC
Flow per
GPH
(GPH) (hp) (hp/GPH) (lb/h/hp)
6.0 38.6 6.43 0.934
6.1 44.7 7.33 0.820
6.2 50.6 8.16 0.737
6.3 56.2 8.92 0.674
6.4 61.5 9.61 0.625
6.5 66.6 10.24 0.587
6.6 71.4 10.82 0.556
6.7 76.0 11.34 0.530
6.8 80.3 11.81 0.509
6.9 84.4 12.23 0.491
7.0 88.3 12.61 0.476
7.1 92.0 12.95 0.464
7.2 95.4 13.26 0.453
7.3 98.7 13.52 0.445
7.4 101.8 13.75 0.437
7.5 104.6 13.95 0.431
7.6 107.3 14.12 0.426
7.7 109.8 14.26 0.421
7.8 112.2 14.38 0.418
7.9 114.4 14.48 0.415
8.0 116.4 14.55 0.413
8.1 118.3 14.60 0.412
8.2 120.0 14.63 0.411
8.3 121.6 14.65 0.410 Fuel flow for best efficiency
8.4 123.0 14.65 0.410
8.5 124.4 14.63 0.411
8.6 125.6 14.61 0.411
8.7 126.7 14.57 0.413
8.8 127.7 14.51 0.414
8.9 128.6 14.45 0.416
9.0 129.5 14.38 0.418 Fuel flow for peak EGT
9.1 130.2 14.31 0.420
9.2 130.8 14.22 0.423
9.3 131.4 14.13 0.425
9.4 131.9 14.04 0.428
9.5 132.4 13.94 0.431
9.6 132.8 13.84 0.434
9.7 133.2 13.73 0.438
9.8 133.5 13.62 0.441
9.9 133.8 13.52 0.445
10.0 134.1 13.41 0.448
10.1 134.3 13.30 0.452
10.2 134.6 13.19 0.456
10.3 134.8 13.09 0.459
10.4 135.0 12.99 0.463
10.5 135.3 12.88 0.466
10.6 135.4 12.77 0.471 Fuel flow for best power
10.7 135.4 12.65 0.475
10.8 135.4 12.54 0.479
10.9 135.4 12.42 0.484
11.0 135.4 12.31 0.488
11.1 135.4 12.20 0.493
11.2 135.4 12.09 0.497
11.3 135.4 11.98 0.502
11.4 135.4 11.88 0.506
11.5 135.4 11.77 0.511
11.6 135.3 11.66 0.515
11.7 135.2 11.56 0.520
11.8 135.1 11.45 0.525
11.9 135.0 11.34 0.530
The best efficiency is with a fuel flow that is about 0.6 to 0.7 GPH lean of peak EGT. If you go leaner than that, the hp per fuel flow starts to drop. At this condition, the power is about 9% less than peak power, but the fuel flow has dropped about 22% from the fuel flow for peak power. The efficiency, in terms of fuel required to produce one hp, is about 13% better than at mixture for best power.
The guys at APS have put together a chart that very much describes what your saying about efficiency. I got this at the APS class, probably the best money I have ever spent on a class before. I knew engines pretty well when I went, but it just brought it all together. They go into the physics of whats happening, including engine pressures at degrees of rotation of the engine. They call it Theta PP (crank angle at peak cylinder pressure). Without a long drawn out description, you get peak pressure later after TDC which is less pressure on Con rods, cylinders, valves, etc...
The gist of it is pretty straight forward and matches what you posted. There is a new term on there called ICP (Internal Cylinder Pressure). They have a cool pressure transducer they designed that can monitor the engine internal pressures to get that. The best measure of efficiency is BSFC, which basically is power produced per unit of fuel. You can see the most efficient setting (as measured by BSFC) for the engine is about 25 degrees LOP and drops only slightly out to 50 degrees LOP. After that the engine will start to lose power pretty quickly. I run LOP not because it saves fuel, but because I believe that heat and pressure is the enemy of my engine and these settings are better for the engine. Provided of course your Air Fuel mixtures are tight enough to do it, typically only on FI engines.
On the chart, what do the numbers 1.66 and 2.63 mean? I don't think they are BSFC or HP. They could be the inverse of BSFC for charting purposes. (1/2.63=.38) Is the chart copyright or may it be freely distributed? Thanks.
I'm not sure I understand the chart completely. It was my understanding that the rich side of peak produces more HP.
When I was measuring IAS during fuel flow testing, it was greatest at 75F ROP. It also dropped off slightly just as I reached peak. According to the chart, most HP is developed on the LOP side of peak. According to my airspeed indicator, it doesn't agree with the chart.
What am I missing here?
The way I read the HP curve it peaks just about 75 degree ROP (the black line). The brown colored (bottom line) is an efficiency measure (BSFC) which basically says you reduce FF more quickly than you reduce power production when LOP. I think you might be seeing the labeling, which is a bit weird. The BSFC label applies to the bottom line and is on the left side of the graph. Its easy to see the black HP label and apply it to BSFC.
This ancient Lycoming power from fuel flow data I have seems to suggest a bSFC for your engine in the range of 0.46 at best power. But at full rich the bSFC should be quite a bit higher than that. I'll venture something on the order of 0.55 as a SWAG. Assuming you really have a 280 hp engine, I think I'd want to see at least 23 gph. I suspect you'll actually see 25 or 26 gph.I apologize as this is not quite over the plate in this conversation, but it's still in the same ballpark, I think.
It appears from the graph provided by Kevin, that useful bSFC's run from approximately .410 to .471 but these only apply at LOP. I will fly my Rocket this summer and was wondering what I should expect to see for fuel flow on takeoff at full rich? I'll be at sea level, turning 2,700 rpm on an IO-540 with AFP fuel injection (FM-200) and 9.5 to 1 pistons. I have been told to expect something on the order of 280 hp. A quick check shows a pretty big range of fuel flows if you plug in bSFC values from say, .40 to .50 of from 18.7 gph to 23.3 gph. It might be nice to know on initial takeoff if I am seriously lean at full power or not.
Any ideas on what I should see, or even more to the point, what the bSFC should be under these conditions? Assuming the bSFC in these conditions is well established, shouldn't I be able to legitimately "back out" my hp at full power from my fuel flow? I imagine many RV-10 guys have this same or a similar engine configuration.
Here are the graphed results that Kevin is using some of the other data in another post regarding fuel flow and power. Best IAS was at 9.2 gal/hr when #4 was 75 LOP but the others were approximately at 90 ROP. I'm hoping to see the flow rate drop to around 8.8 when all cylinders will be close to 75 LOP.
I'll post again after replacing the #4 restrictor to verify the change.
A friend of mine just forwarded me this article from ECI regarding rapid leaning. I would like to hear other's thoughts and practices.
http://www.eci.aero/pdf/93-6-7.pdf
Thanks!
Jon D.
The article provides so little information it is essentially useless for anything except inspiring fear. There are many many people going LOP using "the big pull" with no I'll effects and lots of good effects. If it makes you squirm, use the other method of leaning gradually by adjusting every 1000 to keep EGTs at takeoff temps.
Erich
Now, most important to know, where is really the so tamed Red Box to be avoided ?
To know the right thing to do, we should first know what NOT to do under no sircumstances, right ?
Lycoming recomends Peak under 75% and that's it ! So, where is the Edge?
That's the question... Where is RED BOX ?
Here you go - read these columns by John Deakin. He does a much better job of explaining it than I do.
http://www.avweb.com/news/pelican/182544-1.html
Lets face it from this side: http://www.lycoming.textron.com/support/troubleshooting/resources/SSP700A.pdf
The article seems to focus on LOP operation of turbocharged models.
I'm not advocating one view or the other. Personally I would like more data. I have written the Thunderbolt folks at Lycoming and asked when they will have a complete engine power chart available for my IO-390. Unlike power charts for other models, the current IO-390 chart has no detonation limit line.
In my C-172 with IO360 and matched Gami-jectors, it never gets rough. I simply grab the mixture and pull it until the RPM begins to sag, then fine-tune it. From ROP to LOP is maybe 2 seconds, not even enough time for the EGT's to react. With a FP prop, I level out at my desired cruise altitude, and as the engine RPM reachs and exceeds 2550 with increasing airspeed I do the big pull.
With a good mixture distribution from well-matched injectors, you never feel the roughness from leaning - you just lose power. I can make my engine run smoothly at WOT and 2000 rpm just by leaning it, and it runs way cool. Standard cruise for me is 6k-8k, WOTLOP and control power by mixture to maintain the desired RPM. The throttle stays wide open from takeoff until descent, at about 5k' I go back to ROP and control power with the throttle. I normally true out 118knots on 7.7-8.0 gph.
