Using stick switches?
One of the things I've noted in many posts is the use of buttons on military style stick grips for various operations like starter or flap or ident, etc. From my military background, this always strikes me as odd. In actual military aircraft, many of the buttons on the stick did VERY BAD THINGS, often ending in explosions, so having items which were used casually operated via stick grip buttons was the exception rather than the rule. I do remember that nose wheel steering was operated in that way, but little else.
Start buttons (no keys used in military or commercial) were on the forward panel, flap operation was by levers located near the throttles, ident was on the radio face plate. Even the radio transmit button was located on the throttle and operated by the left hand, lest one accidentally "transmit" an AIM-9 towards Lead when all you wanted to do was say, "two."
No doubt those buttons are tempting, and even in the military I thought it less than convenient to transmit with my left hand while flying with my right, and then have to tune the new radio frequency from memory after removing my left hand from the throttle. Still, we had to respect the possibility of "Master Arm" failure when playing around stick buttons just as you have to respect the possibility of ignition grounding when playing around a propeller.
It's all what you've grown up with.
