Opening up the proverbial can of worms here, but who is still installing a keyed ignition switch on their plane (as opposed to two mag switches and a starter button)? Why and why not?
Just a thought:
With a keyed ignition switch, you are stuck with only starting on the left mag.
I have a left impulse coupled mag and right, electronic ignition.
I have toggles for both.
I can start on either. I typically start on the lightspeed.
As an added benefit, I spin the prop for a couple of blades before I hit the ignition.
You can indeed start on both mags if you wish, there are jumpers on the switch that contol that function, no jumpers = start on both mags.
For my own aircraft I chose toggles and pushbutton starter.
If I recall, there are jumpers on the back side of the switch that govern which (if any) sides ground in the start position. I think you can have a key switch with impulse couplings on both mags.
Dan
Dan
I will have two toggle switched in my new panel. One is an on/off switch for electronic ignition, the other a three position which grounds the mag, ungrounded the mag or, with a momentary, energizes the starter solenoid.
My airplane is always hangared unless I can't find space for it on the road. If its outside its locked. If someone gets into it and starts it what happens is their own lookout. I'll be upset if the plane is lost or damaged, but its insured.
Mel,
I like the idea of the separate toggles for the mags as well, probably locking. it's just the total switch count. Especially if I have Pmag test switches.
Any concern about having what some might consider a non-standard configuration with your starter switch / Avionics Master dependency? I realize most people keep their Avionics Master off during start, but not all it appears from other threads.
We all need to always treat the prop like a loaded gun no matter what system we are using....fully test each method during mag checks and during shutdown and your risk will go way down.
No. All an impulse unit does is crudely re-time the Mags at v low RPM, which the variable timing P-Mag does as part of it's design.I was curious about pmags and starting. Can someone explain this please? The emagair website doesn't really cover it well. I'm guessing there isn't a need for impulse type additions.
I'd say that prop is repositioned.
Since someone brought it up I was curious about pmags and starting. Can someone explain this please? The emagair website doesn't really cover it well. I'm guessing there isn't a need for impulse type additions.
[*]Extension of above, if you ever get that nagging feeling "did I leave the Mags On?" answered if the keys are in your pocket. Aircraft with simple Mag switches seem to me vulnerable to leaving the Mags on - this by experience both mine and others... which of course is a human failing, not the switch design.
[/LIST]However, it is clearly only a personal preference issue...
I plan to test mine during mag checks. One quick move to the off position will let me know the ground is still working. This should cut the risk of this failure mode way down.
I was going to do the "timed" enable switch on the -8 as well. Even bought the little programmable relay... Ultimately, I did not love the added complexity of the circuit. I think the concept is sound however, especially if coupled with the oil pressure switch to ensure the starter could never be engaged with the engine running.
Good idea! But do it at a low rpm. Switching the ignition off at high rpm can be very detrimental on the engine.
I do a momentary mag grounding check the last thing before pulling the mixture for shutdown. That way I know I haven't had a switch or p-lead failure during the flight. On run up, if I get the requisite mag drop on both mags, I consider that a good grounding check.
