If you're talking about the Shorai battery, it's CCA is 270amps - well over the max pull from the starter at about 200amps. Continuous approaches zero while the alternator is operating, and my electrical analysis spreadsheet shows a 12amp draw in the event of alternator failure.
>500 hours of operating in MN summers (>90?F), winter (<0?F), VFR/IFR, Day/Night, acro (incl. IAC and mock aerial combat) and zero failures. A complete discharge due to leaving the master on. It's still going strong...
Not the battery being discussed.
Cad file?
Has anyone made a cad file for a battery box shim for a shorai battery in a pc680 battery box? Figured I?d check here first. Seems like it would be a neat 3D printer project.
