Data here is for my Super Six with an IO-540 and an 80" two bladed D-twist Hartzell paddle, one mag and one Electroair EI (so granted this a bit of apples to oranges, when you consider it against 4-banger RVs, or RV-10s, or Rockets). But I think it's a fun thread, and if you place the results into airplane/RV "classes", it gives us all something to compare to in general (and as an RV brotherhood, something to be proud of...heck, I'm darn impressed with the speeds all RVs attain!)
I did a number of 4-way GPS runs recently, on multiple days, as I prepped for the Pagosa 100 race. Really wanted to get an idea of how accurate my airspeed indicator (Dynon D100) is, and see what I might expect to run in the race. Since I live in Reno, the tests were at 8500' (which also somewhat mirrored the "average" altitude of the course in Pagosa).
I did several runs at various RPMs, to get an idea of the accuracy of the IAS/TAS from the Dynon (and my pitot/static system) at various speeds. What I found was that my Dynon TAS readout was indicating 2.5-5.0 knots fast, when I calculated the TAS from the 4-way spreadsheet from Kevin's site (and Kevin, the standard deviation was always less than .5...even had one that was 0.0, so I think it was pretty good data).
In my max power runs, I averaged 205 kts TAS on the Dynon, and the GPS results showed 202.6 KTAS avg.
In the Pagosa 100, during the level portions I was seeing about that same 205 KTAS on the Dynon, and I ended up running 203.88 KTS/234+ mph for the 100 miles. Granted, there were some downhill portions and some uphill portions, so it's not a scientific validation of my earlier test runs...but it correlates pretty well in a ball park fashion.
The fastest EFIS speed readouts I have seen was with Pierre while racing Steve Barnes side-by-side in his Super Six at 3500 feet on a cool day a while back. EFIS readout was 209 KIAS/218KTAS, which penciled out to 251 MPH. GPS groundspeed readout was also 218 kts, and we had a small direct x-wind indicated, so, although it was not scientific at all, things seemed to match up pretty well (and this was before I did indicator error testing with the GPS method, so I won't yet claim that as a true top-end!) But it does show an increase in speed at a lower density altitude, FWIW.
With respect to Kevin's comments about using the IAS/TAS indications once you have determined the error in your system, I think that is a fair statement for ball-park comparison work (which is what I'd call the 218 kt result above), and would agree that it would be much easier and less expensive, gas-wise.
I'd also agree with Bob A, in that if one was really trying to determine how much a specific speed mod (or even a change in weight or CG) might have on real top speed, that I'd prefer to use the GPS method, and try to duplicate external conditions, to make it as scientific and repeatable as possible. Applying the rigor would be a good thing when you are getting to the nitty gritty, but Kevin's quicker method might be usable for making initial gross (versus fine) measurements of speed changes following mods (perhaps throw a mod out if you can't get close to previous top speed after making the mod).
So as I start to make some speed mods in the quest for catching some of those fast Rockets, I'll likely use both methods as I go along. One goal will be to run a future race and hit or break 250 mph avg speed (will likely have to be one near sea level!)
On the speed dash, Bob or Chris can confirm this, but I believe the racers were required to be level for 5 seconds before entering the speed timing trap, and the desired result is a level top speed. Wind is of course a factor, and might change from run to run, but the two (opposite direction) runs were averaged to get the speed result. Perhaps not totally scientific, but certainly a very fun way to get some speed comparisons!!
Sometimes its fun to be scientific about all this, while at other times its fun to be in Rick's corner and just enjoy the fact that we can blow the doors off spam cans, or see the look on the face of a pax on their first ride in our RVs...showing them the beauty of an airplane that can do so many things so well, perhaps better than any other aircraft (go fast, go slow, to/land at short fields or blend in with high speed traffic at busy airports, do short fun hops or long X-Cs...or go upside down!).
So how fast is my RV...fast enough I guess...but maybe not as fast as it's gonna be!
All intended in fun!
Bob
