moandor
Member
My RV-6A (I didn't build it) has a Trio EZ Pilot autopilot, but it's not connected to any GPS input. So it's only able to be in wing leveling mode. I have an NMEA0183 GPS receiver similar to this one. According to Trio's manual, the parameters should match (4800 baud, NMEA, 8-N-1, etc.)
After I connect it, the autopilot detects some input (it automatically switches to course mode), but keeps showing "NO GPS". I also have an FP-5L fuel gauge. In MPG mode it shows "on", which means it connects to the GPS receiver, but cannot get the ground speed data. All these behaviors are the same regardless of being on the ground or flying.
I connected the GPS receiver to a computer and read its output. Everything looks alright. Position, ground speed, course, etc. appear in sentences $GPRMC, $GPGLL, $GPVTG and such. But it doesn't have magnetic variation data. Maybe this is the problem?
Has anyone had success wiring a similar GPS receiver to Trio EZ Pilot? Am I doing something wrong or is it just fundamentally incompatible? Thanks in advance!
Microcontrollers tend to use “TTL” signals which are 0-5v or 0-3.3v which is probably what your GPS spits out, but most avionics use rs-233 signals which use -15v to +15v which rejects a lot of interference.
Try using an adapter like this and see if your GPS starts working once you are sending the correct signal levels.
I think my GPS is using RS232. The voltage between the tx pin and ground is negative as measured by a multimeter. I also used an RS232 to USB adapter like this to connect it to a computer.
Would it be that the gps puck is only giving position data out? The Trio head is looking for a gps generated course line (flight plan line) to follow.
Yea the GPS has no flight plan information. So I expected the autopilot to enter "NO FPLAN" mode and can only operate in course mode. I should be able to give it some course degrees and it keeps flying in that direction.
I have an older Apollo GX65 and wired it into the Trio EZ Pilot. At first I couldn't get it to work just like you describe. Then on the GX65 I hit Direct Enter (with the direct being my home airport) and within 30 seconds the Trio EZ Pilot started working with the GPS signal. Without doing that, the Trio says it doesn't have a GPS signal.
Trio's support is fantastic and you could pose the question to them. They said they have many GX65's that don't do this so I'm assuming it is some setting inside the GX65 that is not sending the course or stream until I give it a destination.
For your little GPS device you are using it looks like they sell both TTL and RS232 versions. If you have a TTL one it will not work without a TTL to RS232 converter as mentioned in #2 and #3 replies above. Also make sure the TX out of the device is going to the RX on the Trio.
Also the link you provided shows this is a 3.3-5V input power - how are you powering it in a 12V system? Under the description states needs input power of 3.3-5 volts. If connecting to a PC that is supplied on the PC port.
I bought a 6A and it has the EZ Pilot, and was connected to a Garmin GPSMAP 396, and worked fine. Removed for a GPS175.
Good luck
Used an EZ pilot for 10 plus years connected to Garmin 396, 496, IFly 200, IFly 240 and various other Garmin GPS.. EZ Pilot works very well, when connected to any device capable of outputing NEMA data stream. Actually what your looking for is a NEMA RS232 output+ and input - (sometime referred to as TX and Rx) from that GPS to connect to the EZ pilot. The picture you provided looks like an antenna which connects to appropriate GPS and provides position data to that GPS.
