Captain Avgas
When I apply takeoff power to my -9A the stick is full back. When in 50 ft the nose leaves the ground and I ease pressure to just keep it off the ground. The plane does the rest by itself.
Kent
Kent, It's an interesting point. When I did my transition training with Mike Seagar (RV6A) he recommended elevator neutral at application of power for take-off and then gradual back stick to get the nose off the ground as soon as elevator authority became available.
I always presumed he taught this because it is easier (more controllable) to INCREASE elevator to get the nose just off the runway in the take-off roll than it is to DECREASE elevator to achieve the same thing.
I presumed he had seen many students with full back stick suddenly find the nose gear way too high...and then over compensate in the opposite direction causing the nose gear to bounce.
At any rate I just follow his advice and apply back stick gradually just after the start of roll and I can feel elevator authority emerging. That way I don't have the nose rearing off the runway suddenly and I feel in better control.
Just another perspective.
