Could the GTX 45R work with a Dynon HDX ?
Unless I am miss-reading the features, a GTX 45R would replace both the 'SV-XPNDR-261' and the 'SV-ADSB-470', reducing box, wire harness, and antennae count by one.
Hello Rodrigo,
Good question.
If you are installing a GTX 35R or GTX 45R transponder with a G3X or G3X Touch system all of the configuration of the remote mount transponder is done through the normal configuration mode XPDR page on the PFD, so the install tool is not needed.
We added thousands of lines of new code to G3X and G3X Touch systems to support the new and extensive configuration requirements of these new transponders so our customers would not need a computer and an installation tool to configure the transponders.
If you have a GTX 335 or GTX 345 panel mount transponder, the configuration is done through the front panel, and again, no computer or configuration tool is required.
Presently the only method of installing software updates is through a Garmin dealer, but we are considering other options.
We have been performing free software updates on GTX 23ES and GTX 330ES transponders for EAB customers at SNF and Oshkosh for several years, and will likely add support for these new transponders for those attending these shows as well.
Steve
Hi Steve, I have just got my setup configured and running. I have a 45R and 10" G3.
The question is, as we don't have UAT(TIS/WX), but the WX page shows on the display and the UAT status says not connected on the traffic page. There is no option to disable these features in the transponder setup page on the G3. Would disabling the UAT in the transponder with the Config tool have these items disappear on the display?
Cheers.
Bruce.
I am correct in assuming there are some overlap between the GTX 45R and GAD 29 ?
I a setup with GTN 650 and GTX 45R, what would be the function of GAD 29 ?
