OK - can you tell us exactly what your operating technique is on these flights that produce this close approximation, startup to shutdown? I'm just trying to pin down the differences between what people are seeing, and figure out what is different and where the error might be. If you get this result with the boost pump off and operating on the engine driven pump, then your first statement that this scenario produces a lower-than-true flow indication cannot be correct.
First off, Kahuna's flow sensor was installed before the mechanical pump, on the suction side (if I understand the situation correctly). My sensor is on the pressure side of the mechanical pump about 8" ahead of the FM200 controller inlet. It is never subjected to sucked fuel anomalies.
The electric pump is ON for start, for take off and landing. It usually is turned OFF at about 1000' AGL climbing. It is turned ON when switching tanks.
There is a fuel pressure drop from about 27 psi to 22 psi when the pump is turned OFF but there is no change in fuel flow. That is so because there is always a head of pressure on the sensor from the electric pump or the mechanical pump or both. Kahuna's sensor did not have a head of pressure on it when the electric pump was OFF.
None of this is an absolute exact science. I had a sensor in the Cozy that never had a head of pressure on it and it too was very accurate. But it was a gravity flow system. I do believe a high pressure fuel injection system with the mechanical pump sucking and pushing fuel is not the best environment for the flow sensor especially on the suction side. Some may work, others won't. For sure Don is on the right track installing the sensor in the line between the controller and flow divider as the pressure is relatively steady and low. I did not install it there because I did not have the 1/4" hose fittings but did have two AN6 hoses just the right size coming from the mechanical pump.
Matt Draille at Matronics sells one. The Pulsation Damper (PD) is a stainless steel sphere with a fitting on one side that connects to a 'T' AN fitting and is placed in-line with the fuel flow either just before or right after the fuel flow transducer. The PD acts like a common 'air shock absorber' isolater in a typical sink facet. The air is compressed inside of the sphere in time with the pulses in the fuel line caused by the boost pump and/or the mechanical fuel pump. This extremely simple device is incredible effective at reducing the fuel flow reading fluctuations common in turbine transducer-based electronic instrument installations. Below is a paraphrased testimonial from a customer on the use of the PD in his 0360 power RV-8 installation.
Sorry for the blurry image. The fitting is a custom fitting that was welded up. Works perfectly. The transducer is in a nice cool place, with no mickey mouse fittings or firesleeve wrap required.
...For those cases where the flow meter reads high, or incorrectly when the boost pump is turned on and does not return to a lower flow, I would suspect that there is some kind of EMI or error in the instrumentation due to current load. I am no authority on electronics so do not assume this statement is correct; It’s only a theory. ...
Don
From Kahuna's OP, I interpreted it that when the boost pump was turned on, and FF went up, innacuracies were generated in the fuel burn and fuel remaining calculations that were significant enough for him to not use his boost pump at times when he otherwise would. Am I reading that right Mike?
.......putting the fuel flow transducer after the electric pump gives bad data with the electric pump on. Flow increases +2gph with the pump on. No change in any other engine parameter except fuel pressure of course.
The engine is not getting any richer. Im not burning any more fuel. There is no place for the fuel to go after the sensor except to the engine in my installs. SO why on earth does it go up when the pressure increases and no more fuel is going by?
In any fluid system, good design takes careful analysis to ensure that local cavitation does not occur.
Brantel, on your post, I'm not sure I follow. Are you suggesting at a flow rate of 10 gpm plus a hour, there are flow reversals? I've seen mag flow meters "count" on a deadheaded line when the system had quite a bit of vibration. Maybe a turbine meter would as well, but not sure how that translates to the symtoms that Kahuna has described (scenario one).
Thats exactly what I am saying... It is clear that the impeller in the transducer is producing extra counts when the boost pump is on. The only way it can do that (since we know it is not real mass fuel flow) is to be oscillating back and forth and one reason it could do that is the reverse flow caused by the collapse of the volume in the lines/system when the pump pulse is over or at its low point.
I stated that "the only way" to get extra counts is for the impeller to be oscillating. There are many things that have been offered up as reasons why it could be oscillating and I offered up my idea, notice I say "one reason it could"...Don from AFP has already confirmed that there is a volume change in the "System" with pulses from the pump. I would say that he has confirmed this with testing.
I do not buy the theory on electromagnetic interference causing the extra counts due to many reasons too broad to discuss here.
Just my opinion and it ain't worth much...![]()
Caveat: don't expect the fitting between the flow divider and the sensor to be able to support the sensor on your vibrating Lycosaur (especially if it is aluminum) - add a support for the sensor.
A sniffle valve will help the hot-start problem too.
Carry on!
Mark
I get the same symptom on the el cheapo Lowrance marine totalizer in my carb'd O-320. I doubt that the 3psi Facet can push hard enough to swell stainless braided lines (though a Walbro positive displacement pump might).
Yep beer is always cold. Maybe I should make some koozies out of firesleeve material?
Serioulsly though why wrap the hampster wheel but not the divider and the lines?
