Kahuna
Moderatoring
Over the years I have had a few installs of fuel flow transducers on injected motors. Having followed the instructions, I have not had good results. My main problem has been that putting the fuel flow transducer after the electric pump gives bad data with the electric pump on. Flow increases +2gph with the pump on. No change in any other engine parameter except fuel pressure of course.
This has annoyed me to no end and has even caused me to not run my pump on occasion, when I should be, to keep my FF readings accurate to maintain good time to dry numbers on the monitor. Thousands of RV hours with wrong fuel remaining calculations. Frustrating. But since I have tank indicators, terrible as they are, well I just fudged and guessed on gallons remaining off the FF calc.
Folks for years have been complaining about the same issue. It was always a head scratcher for me. Why does the number go up? The little turbine wheel is not going any faster. The engine is not getting any richer. Im not burning any more fuel. There is no place for the fuel to go after the sensor except to the engine in my installs. SO why on earth does it go up when the pressure increases and no more fuel is going by? I dunno.
After a recent upgrade to 97gallons in the wings, I had a need to really have accurate and reliable FF numbers and hence have had a good reason and need to fix the problem. I can no longer tolerate inaccurate time to dry numbers.
I moved the FF transducer off the fixed mount on the firewall into the plenum area before the spider. This cured the problem. May create others later.
End of report.
End of report.
