cjguppyguy
I'm New Here
Patron
F S Rotax 912ULS-2 2017 sn 9569271
Professionally overhauled and installed 1484 High Power and Zipper Cam kits. New carbs and fuel pump. Gearbox overhauled and prop shaft spline oiler installed. Newest OEM type oil rings installed preventing oil use. Engine ring mount, oil tank, electric Facet 12V #40-105 fuel pump, Rotax Service Bulletin compliant Fuel Manifold with tank return and pressure sensor port, and exhaust - all less than ten hours.
1240 - TT, 10-SMOH. $16K
More photos and logbook pages available upon request.IMG_8326.jpegIMG_8319.jpegIMG_8328.jpegIMG_8316.jpegIMG_1528.jpeg
More photos and logbook pages available upon request.View attachment 118537View attachment 118538View attachment 118539View attachment 118540View attachment 118541
The replacement Oil Rings are from LN Engineering of England. The OEM Oil Rings in the Big Bore Kits were replaced with an aftermarket ring that did not seat well in the cylinder. These LN Engineering two-piece Oil Rings resolve the Big Bore oil use issues .
