L.Adamson
Bob Axsom said:At airports in densely populated areas I personally would turn back even if there was little hope for my personal survival.
I flew R/C's for many years, and quite a few with heavy wing loadings and low glide ratios. And several of our R/C "airports" didn't have bare enough surroundings for successful off field landings.
Between a number of unsuccesful return to the runway scenarios by myself, as well as witnessing many others, I've seen numerous R/C airplanes just drop a wing & spin in. At that point, there is no control whatsoever, and whatever is underneath the unintentional crash spot, is forever underneath.
Because I've seen quite a few results, of return to the runway stall/ spin "crashes", that happily envolved non-piloted airplanes, I've resolved to never try it, unless I know for sure that I have the required altitude, through prior testing.
A few years back, I seen a Cessna 152 perched in a tree against a building in a very crowded shopping center parking lot. The student pilot had run out of fuel, and having no good options, went for the tree. The pilot survived with only a few scratches, and even the airplane was not too beat up. IMO, this is my option, which is to stall at the last second into a tree if needed.
Just last winter, a Cessna 310 performed a last second stall into a 45 degree mountain upslope within sight of my home. Again, both the pilot & passenger got out of that one with a few minor scratches. I think the last second stall to dissapate as much forward speed as possible, is preferrable to an un-controlled last second spin possibility; even if it's into something that the pilot might not survive, but hopefully avoiding people in the path.
L.Adamson
