eric_marsh
I'm very early on in my RV-6 project. I've been thinking about fuel and oiling issues for aerobatic flight and that led me to considerations of fuel injection. That in turn led me back to thinking about using EFI.
I realize that there are fewer benefits to EFI in engines that more or less maintain a constant load than there are in automotive engines. But there are still benefits along with negatives.
From this point forward please think of this as a though experiment.
I'd like an 0-360 but have not yet purchased an engine so that choice is still open.
Taking the EFI question one step further, I got to thinking about how nice a closed loop system with o2 sensors would be. With the fuel air ratio tied into the throttle the system could do most leaning and adjustment for air density automatically. Carb icing would not be an issue and each cylinder would always have the correct fuel/air ratio. Because carb icing isn't a problem there is no need to run the intake through the sump, creating a cooler charge and more power. Easier starting is another benefit.
My Hayabusa's injectors provide enough fuel flow for 250+ horsepower - easily enough for a 180 horsepower engine. I suspect that it would be relatively inexpensive and not too tough to adapt a motorcycle EFI system to an aircraft engine.
The most significant downside I see to EFI is that it REQUIRES 12v. Consequently it's dependent on having an alternator/generator that is working.
I've got a couple ideas on that. One is simply a backup alternator. Another one that I think is interesting would be to also have a carburetor on the engine. EFI still needs throttle bodies so why not use a large carb to do the job. Set up a fuel shutoff to the carb so that it simply acts like a throttle body but in the event that the EFI system fails the carb can be fed fuel and act as a backup system.
Of course 02 sensors require unleaded gas. That brings me to my next thought - mogas - with ethanol.
We will probably be seeing the mandated use of unleaded at some point. It seems to me that since I'm building an airplane now is a good time to look forward to that eventuality.
These are hot subjects - so much so that I've not yet reviewed all the posts. I'm going to continue to do so as time permits.
Having said that, I'd like to focus on four subtopics.
1> Availability of mogas at airports.
I'm not seeing mogas at the small regional airports that I've frequented. Is this an issue?
2> The effects of 10% ethanol on aluminum
Most fuel system components can be upgraded for alcohol without difficulty. The two components that I'm thinking of are the tank and fuel lines.
If necessary the fuel lines can be replaced with steel. It would add a couple pounds to the airplane but it that's the safest solution then so be it.
The tanks are another story. I just don't know if it is likely to be a problem or not. If it is, I have to wonder if the inside of the tanks can be coated with an alcohol tolerant material.
3> The need for lead to lubricate valve faces and seats.
This is a subject I've not seen discussed much. I worked in an automotive machine shop back in the seventies when lead was removed from automotive fuels. As a result of this I saw a lot of hammered out valve seats and valve faces. The manufactures started flame hardening the valve seats to counter this tendency but the best (and most expensive) solution was to put in stellite or hardened seats.
I'm wondering if this would be an issue with aircraft engines. On one hand they are designed for leaded fuel use. On the other, they use seat inserts and one would think that they are using good materials. So this is a big question in my mind.
4> Long term fuel storage
There's not much that can be done about this except draining the tanks or using a fuel stabilizer and testing carefully.
I'm a long way from installing an engine but since I am about to start on the wings this seems like a good time to consider issues relating to the fueling system.
Thoughts? Ideas?
Thoughts? Ideas?
