Flyfalcons
Why beef up what has been working?
It would be a great thing to see both designs flipped over on a jig and load-tested to failure!![]()
If you do the load testing with the wings upright, you need hydraulic rams and a complex arrangement to spread the load, pushing upwards on the lower wing surface. If you flip the wing upside down, you can use the force of gravity pulling on sand bags which are piled on the lower wing surface. This is a much cheaper solution than hydraulic rams, so it is the preferred method for general aviation load testing.why would they get flipped over? I've seen some load testing done, it was with the flying surfaces upright iirc. i have some video and pictures, i'll dig it out and watch
Can you use a 200 hp io360 like you can in the 7?
Is the 6 faster than the 7 at the same hp?
Is the slightly smaller size really an issue?
Steve
It just looks stronger although Van will tell you it's not.
I know the 7 has the quick build option which means it will probably be built better. Harder to make a mistake.
There's a lot of info on the strength of the RV-6 wing if you do a search here for "increasing gross weight" and things like that. There's been a lot of discussion, and a lot of armchair reverse-engineering by experts and yokels alike.I don't want to sound argumentative, but this is not how engineering works. First, the designers/engineers of the designs will (should) have done both analysis and testing to verify their designs are sufficiently robust. They do not go by what "looks stronger". If the engineers who designed these planes tell me that one design is stronger (and we'd have to be careful to make sure we understand what "stronger" really means) than another, seems to me that one should accept their expertise here. There are many ways to skin a cat, and what looks to a non-expert like a better solution may, in fact, not be.
It would also encourage a lot of -6 owners to start flying with an extra 200lb on board, without a lot of thought as to how it would be distributed...
I'm not guilt-free of doing such things, either, by the way...I have a Sikaflexed canopy! But, I did a simple bond strength test to see how strong it was and I read of numerous others who tested it,![]()
In reality, there are a lot of 6s that have been carrying that extra 200 lbs. At least for 17 years that I know of. Of course we do figure in the proper W&B..........which amounts to no problem at all. Gross weights ranging from 1750 - 1850 lbs. are common. I've seen as high as 2000.
And none of them have any engineering data to show that it's safe... They're just taking it on faith that if the last guy who did it is still alive, it might be okay.
I have owned and flown 3 RV6 models. A 6 with 150HP and a Catto prop, a 6A w/160 HP and a Catto prop and our new baby a 6A with 180HP and a Sensinich metal FP prop. I have flown 7's, 9's and a 10. Here is my simple opinion. Being "full figured", 220lbs, and having flown with at least 1800 lbs gross on all of my planes, I can only say that they all fly great. I still prefer the Catto prop over the metal one as it is lighter and tends not to windmill when the power is shut down thereby making landings a little more predictable. Quoting a friend of mine," the only time my plane acted like a real airplane was when I was loaded at over 1800lbs and took off at 6000 ft density altitude." I am always more concerned with proper CG loading than actual amount of weight. (Of course this means within reasonable limits) Higher weights just mean that I will have a takoff roll almost as long as a Cessna 172. That being said I do prefer 180HP for getup and go. I still can't justify a CS prop. After all that, just get one and go. You won't be sorry with any RV of choice.
L.Adamson --- RV6A
Well, I admit that i've only been following the issue for 12 years. So I may be a little out of touch...If that's what you would like to believe.........
Go back & read up on the issue for 15 years or so.
