Do you want to be "IFR" or be able to file and fly an IFR flight plan? To be truly legal everything needed for true IFR flight needs to be certified equipment. Radios, indicators and antennas, installed per the manufactures specs for IFR certification. This does not mean everyone does this, even many certified planes don't conform to the regs.
The DYNON EFIS calculates the values I highlighted based on it's own sensors or inputs from multiple sources (Marker Beacon and/or DME) not just from the SL30. The image shows ALL of the EFIS's display capabilities from all sources.
BTW, the link you provided ( DYNON Skyview HSI ) specifically states it "supports the Garmin SL30 NAV/COM and many GPS units that use the NMEA-0183 or aviation data formats" so that answers my question. You don't need the ARINC-429 module to display all the SL30 information.
You are absolutely correct. Don's post #43 seemed to suggest that he misunderstood what data the SL30 can provide.
The SL30 does not even have an ARINC-429 interface so you can't interface it with ARINC-429 even if you wanted to. The SL30 can do everything it can do over the RS232 serial link. See post #19...
This has been hashed out here multiple times. Coms, VHF navs, etc. Don't need to be TSO'd. GPS does because of one sentence in the reg.
IMHO this makes the Skyview/SL30 a sweet combination for most IFR flights and training.
