00Dan
I’ll be converting from Bendix to Slicks and will need new P-leads. Does anyone know what size ring terminals I’ll need for the magneto end? My searches have come up empty. Is the case stud people use for grounding the same size?
As far as wire size, I’ve seen everything from 14 ga that Bogert uses on the pre-fab wires they sell to some forum posts saying 20 ga is plenty. Is there any consensus?
16 or 18 ga single conductor shielded. Could get away with 20- only a few amps. Wire to p lead and shield to ground screw on mag. Grd screw is #8 (could be a 10, but don’t think so) and the post on the condensor is either #10 or #8, I believe the latter.
Larry
