Scott Chastain
Sponsor
Those of us who have pulled the trigger and purchased Garmin's latest and greatest might want to share their experiences with the AXIS system here. Many years ago, my father taught me how to fly in a J-3 Cub, an Aeronca Champ, and a Luscombe. Those panels weren't anything like what many of us fly behind these days, and some of the best learning experiences I've had in my transition to the all-glass cockpit have come from other pilots who openly share what they've learned. I'm very excited about the AXIS system, and from what I've already seen of it, there will be many, many hours of enjoyable flying to come with a fresh installation in my newly overhauled RV-8.
My installation comes on the heels of a newly installed G3X system. With only 30 hours on it, the GDU 460 got yanked, and I began the installation process of the AXIS in earnest. Using the checklist in the AXIS Installation Manual, I checked for fitment of the 116B behind the panel, then opened up a few backshells to begin modifying the harnesses. I had already created my new wiring diagrams, and I simply followed the directions and pinouts in the manual in execute the plan. Powers, grounds, and a new GSU 25 power-up system directly from the GDU were my first priority:
4 Power Leads to GDU 116B
4-Lead Grounding Harness for GDU 116B
The GPS 175 required a new HSDB connection, so I opened up that backshell and wired it up.
My original G3X installation carried the AHRS on the back on the GDU 460 and worked flawlessly. For the AXIS, the GDU orientation is moved counter-clockwise 90 degrees. So after all of my wiring was tethered and the continuity-power checks completed, I had to make a few adjustments to my plumbing behind the unit. For the most part, the installation came out fairly clean. All of my G3X harnesses had more than enough service slack to make the needed connections.
When it came time to throw the switch, I wasted no time peeling off the plastic and turning down the lights. That glass is sweeeet! Without even moving into the first steps of configuration, I can tell you that the definition of the display blows away anything I've seen before. The pictures here do it no justice at all. Just take my word for it: When somebody uses the term High Definition, this is most definitely it.
Next comes the long process of configuration. With my G3X configuration file and fuel calibrations saved, I'm still waiting for Garmin to release the first AXIS software update.
In the meantime, I can configure the system to interface with all of my previously installed LRUs with the exception of the G5; it, unfortunately, is also waiting for a software update (v8.70) before it will interface correctly with AXIS. Nevertheless, getting airborne and testing it out with a new W&B is getting very close. Until then, for those of us who are upgrading to AXIS from the G3X, I can happily report that the upgrade is truly a snap if you know what you're doing. Just follow the directions in the Installation Manual and you should be fine.
Best wishes, and thank you Garmin for taking my phone calls and answering my questions!
+Scott+
+Scott+
Scott,
Thank you for this write-up! I’m in the initial research and planning stage of doing the exact same thing with my RV8 and your timely review is very helpful. Would love to get a follow-up report after you’ve had a chance to fly with it.
Regards,
James Baker
Hi, James,
You're going to love it! The amazing thing is, I didn't have to so much as remove my seats for the entire process of wiring it up! With the nice big G3X cutout, I was able to get it all done in the seat and didn't pull off a single panel. It was cake.
Best wishes!
+Scott+
After a long, hot day in the hangar, where I spent the better part of my Friday morning and all afternoon in the AXIS Configuration process, I watched the end of the week fading off with the sunset and decided to make a first flight with my new AXIS system.
I was not able to transfer my fuel level calibrations from the G3X over to the AXIS system for some reason. There is an Advanced Import feature where you are supposed to be able to transfer individual calibration curves---like from the left and right wing tanks---from the G3X calibration files that were saved before the GDU 460 had its plug pulled. I followed the directions to the letter, even making sure my USB-C memory stick was formatted to FAT32. I tried 3 or 4 times and failed, so I may have to resign myself to getting the tanks burnt off in the air so I can recalibrate the old-fashioned way: a few gallons at a time, one tank at a time. Later, I cranked over and taxied out to the compass rose where I performed the GMU 11 magnetic interference and compass calibration procedures. It was my first opportunity to watch all of my engine instruments come alive, and man, oh man, she's a sweet upgrade! After I brought the RV-8 back to the hangar, I completed the autopilot configurations and went though the ground checks with no squawks. As the redness of a dying day swept over the tarmac, it was time to get airborne with the new AXIS system.
Taxiing out, the new 3-D taxi scheme came into view and diagrammed my airport beautifully. There was an issue with an RS-232 backup port not communicating with the GEA 24 which was already on the CAN Bus; nevertheless, the AXIS system lets you know in no uncertain terms when redundancy issues pop up. I may have to double-check the pinouts for that port to get them talking again.
At runup, I noticed a vast improvement over the G3X for being able to read my EGTs during the mag/e-ignition check.
With everything checking out in the green, I announced for a departure to the west, taxied onto the center line, and let her rip. It was still about 95 degrees on the deck, so I was expecting a hot climb-out and kept my pitch pretty shallow. I wasn't planning on making anything more than a 15 or 20-minute flight anyway, so I shot for 4,500' and leveled off. I realized quickly on the climb-out that I must have missed calibrating my trim motors because my pitch trim was reversed and I had a non-calibration symbol emblazoned on the screen that I had not noticed before.
At least I was able to configure my PWM lighting bus correctly. As things got a little darker in the cockpit, I threw on the LEDs and experimented with the display for a time. I had not populated my upper status bar with all the elements I enjoyed on the G3X, so I added that to my list of adjustments, then flew back to the east as the city began to bask in the darkness of the coming night.
Back home after a 25-minute joy ride, I got to see for the first time how helpful the 3-D taxiing will be at unfamiliar airports.
With the pitch trim motor and calibrations still having to be made, it is clear that I need to put aside the installation manual and break open the AXIS Pilot User Guide so I can really begin to know my way around the unit. I have a ton of learning ahead of me, but that's what makes this so fun! My next flights will include intercepts, engaging and using the GFC 500 autopilot, and perhaps shooting an R-Nav or two. We'll see. But for now, it's time to get some food in my gut and hit the sack. It's been a busy but exciting two days!
I see you kept the power for the GSU25 The same as the G3X.
The axis manual recommends that the GSU25 is not powered from screen but direct from the aircraft bus. Any idea why?
Hey, Trent,
I have no other use for those two power outputs on the J1011, so I decided to put them to work. Can you think of any better place to run those two wires? Maybe a lighting circuit? Anyway, I felt better about the redundancy of two power inputs rather than having to rely on a 2A fuse to power the whole GSU 25. As to why Garmin recommends the direct bus power, I don't know. That's a really good question. Maybe G3Xpert could answer that for us.
Maybe the output loses power if the screen fails.
If that’s the case:
I was thinking one input to the gsu from the PFD and one from a bus, for redundancy.
Configuring the pitch trim properly, I took off this morning for a breakfast flight and exercised the GFC 500 a good deal. As it did with the G3X, it works flawlessly on the AXIS bloodstream, and the airborne checkout passed with flying colors. As for the fuel calibrations, I'm waiting until Tuesday when I connect again with my Garmin dealer who will bundle all of my databases and charts and hand me the 32g USB-C stick that I need for the Advanced Import function. Apparently, 64g sticks or trying to transfer files through a USB 3/USB-C adapter won't cut it. But getting those original fuel calibrations installed will save me a lot of time and effort. Granted, it won't be the end of the world if I can't get them to work either, but hopefully, I can get the calibrations imported. We'll see how it goes next week.
Heading home after breakfast up in the foothills, there evolved a great example of a potential traffic conflict on my climb-out. It was a Cessna who was also climbing out at nearly the same altitude. I had a good visual on him from about two miles out. As I easily out-climbed him, at our intersection he was already over 1,700 feet below and well behind me. The graphic for selected traffic looks a lot different than what I'm used to (*See subsequent post on what this ring actually is. It has nothing to do with traffic).
I like it. A lot!
Was the AXIS delivered with any mapping loaded ?
If it was could you list which products.
Hi, Burnie,
Yes, there are databases and mapping products loaded into the AXIS system, but they are clearly expired. You'll see that notification during the "AHRS Aligning" process right after power-up. I heard yesterday from my dealer that Garmin was supposed to include (albeit at a co$t) an installation package which contains, among other things, a coupon for a free database download and the USB-C memory stick which I need for the "Advanced Import" G3X fuel calibration. Hindsight is 20/20, right? In any case, you'll be able to fly with the unit as is, but you'll also need to get the charts and maps updated with Garmin.
+Scott+
So, today's flight taught me something about that ADS-B traffic I mentioned earlier. That circle isn't showing vectors or separation at all. It's called a Range Ring in AXIS terms, and here is what the Pilot User Manual has to say about it:
Wow, that is a ton of stuff in there! I thought it had to do with traffic because placing my finger on the airplane symbol brought the ring onto the screen. Anyway, lots and lots to learn here, but it sure is a fun process!
Tonight, I'm heading out for a night flight to test things out some more. I want to get fully comfortable with my cockpit lighting busses and dimming features that were installed for the G3X but now need to be fully configured for the AXIS. I had a little trouble last evening with getting all of my radio stack bezels to light up properly. I'll work through it, though.
+Scott+
Hi, Burnie,
+Scott+
The fuel calibration import is not done via the advanced import function, but via the calibration page for each tank. Not obvious at all…
Hi, Burnie,
+Scott+
If the Terrain DB is already preloaded and is 2020 version it will not be expired.
I would not bother reloading it as this is the 'latest' and will add a fair bit of time due to its size.
You're right! It isn't obvious. Reading digital manuals and clicking bookmarks all over creation can lead to a lot of overlooked details at times, so thanks for the heads-up!
If one reads the section F of the Axis install manual it references 5.9.3 in the G3X install manual version AZ. (below) 5.9.3 is in the new Axis install manual. If you go to 30.4.5 in version AZ of the G3X install manual you will find how to do this also.
I know this was a huge undertaking by Garmin and bound to be some errors in the documentation providing I am reading this correct and was an error.
After that great tip from @svengru, I finally managed to get my fuel tank calibrations transferred over, saving me a lot of time and extra unneeded effort after having already calibrated the G3X installation earlier this year. Thank you, my friend! (y)
Tonight, I fired up the RV-8 for a beautiful night flight so I could toy around with the panel some more and really engage with the AXIS features. On Sunday nights around here, the skies are pretty empty, so I blasted out to the northwest and set up a quick Direct-To, then added a few more waypoints for a quick RV-style circuit around the patch.
The GFC 500 autopilot system, as mentioned in an earlier post, smoothly anticipates each waypoint so that vectoring into the next leg is as smooth as warm butter on a biscuit. I added another 1,000' MSL for the easterly-bound VFR altitude and kept the power on the lean side of peak the whole time.
I got to play around with the HSI mapping feature and the radial menu, looking at waypoint information and modifying the flight plan along the way. I also got to experiment with the point-to-point measuring feature by using the two-finger touch technique, just like in Foreflight, to find out bearings and distances quickly and easily.
I was having so much fun that I didn't really want to stop, but it was getting a little late and I decided to pick up the learning curve on the morrow. I threw on the LEDs for a pre-landing check of the cockpit, then enjoyed a synthetic vision approach on the base-to-final leg of the landing. From what little I've learned of the features so far, this AXIS system is a pure joy to have in the cockpit. I can't wait to see how others configure their side-by-sides with PFDs and MFDs! I'll bet they are beautiful!
For those of you visiting the Garmin side of AirVenture 2026, I hope you find as much of a thrill in the AXIS displays as I do. You'll want to get some RV-torn air under the system right away!
+Scott+
The GFC 500 autopilot system, as mentioned in an earlier post, smoothly anticipates each waypoint so that vectoring into the next leg is as smooth as warm butter on biscuit. I added another 1,000' MSL for the easterly-bound VFR altitude and kept the power on the lean side of peak the whole time.
+Scott+
With the EIS on the right like that, where does the screen put the widgets?
I’m planing a PFD on the left screen with the EIS on the right side.
For the PFD on the right side of the cockpit, I would put the EIS on the left side an the PFD part on the right.
Is that possible? They don’t go into much detail in the manual. I couldn’t find any way to boot the trainer app into config mode to play with the settings.
Hey, Trent,
With the EIS on the right, the widgets will line up just to the left of it. Next time I go up, I can take a screenshot and show you what to expect. I haven't yet used widgets with the EIS on the left side, however, but I imagine they will line up adjacent to the EIS on that side, too.
Are you putting in two displays, a PFD and MFD? With one screen, the options are more limited, but I'm nevertheless finding the versatility of moving things around to be very amenable to personal preference on the RV-8 panel.
+Scott+
Hey, Trent,
+Scott+
I’m planning twin screens (rv-14). So figured it would be 2 PFD’s so the person on the right also had flying instruments.
With the G3X Touch you can have a reversion switch for the MFD so you can have two screen setups; one for single pilot large map window and one as PFD2.
Has anybody looked at this, I am assuming it can be done ?
Looks like still on pin 25, THANKS!
I hadn't thought about installing the switch - but maybe it's a good idea.
So if i installed the 2 screens, instead of installing as PFD1 and PFD2, i could set them up as PFD 1 and a MFD, and if i had the switch installed, i could choose to run it as 2 x PFD's?
Yes, kind of. They won't be truly revisionary, there is only one ADAHRS unit driving them both. More of a "mirror" mode, just displays the same thing on both screens. Good if you have a right seat pilot that wants to fly instruments etc.
fair point.
I was considering the comment in the AXIS manual about powering the GSU25 from seperate sources - i plan to do this. Also, to wire the 2nd RS-232 connection to the MFD screen - so the GSU 25 will have it's can bus connection from the primary PFD, but then a backup RS-232 to both of the main screens. If the PFD (left screen) should fall over, hopefully the MFD will have all the same capabilities. If the GSU25 fails then i'm not sure what happens - whether the G5 will provide attitude data to the main screens or not.
fair point.
It won't, The G5 is a standby instrument, not a standby ADAHRS.
It actually is both. The Axis system is also using it as ADAHRS and you can even manually select as the primary source.
So if your main GSU25 goes down you can still use the axis screens as PFDs by using the G5 ADAHRS?
That’s cool.
Where are you getting this information?
That goes back all the way to my 370 PFDs. Only difference is that in the older systems you had to power down the 25 before the PFD would start using the G5 data. Seems like they finally made that seemless.
