MrNomad
Designing the front gear tests and other elements
Larry: Please write up a series of tests you'd like us to conduct and email the WORD document to me. Chet has wood working skills and so he should be able to build any size/shape "road bump" we need. I have a website and can post the video and any observed measurements we're able to get in one location so everyone can view our progress.
I also have a laptop computer and assume that an inexpensive camera can connect to the laptop via a 20' RCA cable. The camera will be affixed to the trailer and the cable has to be long enough to connect to the laptop in the tow truck cab. I haven't done this so any suggestions for the camera are appreciated. If I break the laptop the wife will definitely kill me.
I will also need recording software for the laptop (Windows 7) and assistance with the software selection would be helpful too.
Overnite, I received an email concerning a Paypal account (I've never set one up) so hopefully another new friend will handle that detail should anyone wish to reduce our out of pocket expenses. We cannot destroy the gear leg we are using so taking the tests to destruction is not an option. However, if enough money comes in we will buy a replacement (latest design) gear leg & fork, tire, tube & wheel, and we'd be willing to submit the jig to more strenuous tests. If people have latest design parts they're willing to donate, that's good too.
Once we depart from my house, we wait until we are on the test road and relieve the lift the scissor jack affords. We can gradually decrease tire pressure and repeat the tests you suggest. Chet can drive ahead and keep resetting the road "bump" while I decrease air pressure for each subsequent test.
Thanks again for the help.
mrnomad57 "at" gmail.com
Please, please avoid designing a test with too many variables (refer to my previous post re simple tests). The calibrated bump can be as simple as a strip of 1/2" plywood secured to the pavement that engages only the nose wheel. By varying weight, tire pressure, approach speed and approach angle w/ multiple runs at each configuration, you are going to have a lot of data to analyze. Once you accomplish all of the above, you can change the height of the bump to 1", etc. etc. That is a lot of testing. If possible, I would consider one camera at a fixed location on the ground ("global reference") and one camera on the trailer ("Local reference")LarryT
