Vansconvert
When buying a quick-build kit, is anything primed from the factory? If so, then is it necessary to do any additional priming to the internal structure?
The reason I ask is there is an RV built in early 2000 from a quick build kit and there is no indication in the log book that it was primed, and looking at the interior of the fuselage it does not appear that it was primed - but there is no visible corrosion.
