Status
Not open for further replies.
I'm betting that the new display will still fit in the lower pedestal location, so if I get that far, I might terminate all my airframe wiring to that point. I won't drill out the instrument panel blank until I know the specifics. The panel blank in this location is quite large, and I have no other plans to locate anything there...
Phil
Marc, come on... tell us the dimensions at least, so we can plan our panels.
Cristiano
Thank you all!
Finally I decided wich avionics to install and found excelent prices in Brazil. Actually it?s a store of USA that operates also in Brazil. My elected config is below...
I?d like to thank you all for helping me with technical infos, suggestions and opinions. Without the precious comments that you posted here I could not be able to find the solution that I?m sure is the best for me.
Thank you all guys! :)
Cristiano
A) TSO Instruments:
1- Davtron Instruments 811B-12 Clock/Chronometer
2- Sirs NV-2C-4000 Compass (blue lighted)
3- Aero Instruments PH502 12V pitot probe
4- Aero Instruments 4511 AOA
5- Aero Instruments Static Pressure Port
6- Aero Instruments 4207 Pitot Static Probe
7- Aero Instruments 4222 Temperature Probe
B) Non TSO instruments:
1- Westach Quad Gauge 3 1/8" Exhaust Gas Temperature 3AQ2
2- Westach Quad Gauge 3 1/8" Cylinder Head Temperature 3AQ1
C) TSO antenas:
1- Comant Ci 120-400 VOR/LOC/GPS antenna
2- Comant Ci 2480-400 VHF/GPS/XM antenna
3- Comant Ci 105-6 DME/XPDR antenna
D) TSO avionics:
1- Garmin SL-30 NAV/COM
2- Aspen EDF 1000 Pro
3- PS Engineering Audio Panel PMA-8000BT
4- Garmin GTX-32
5- Garmin GTN-650 GPS/NAV/COM
E) Non TSO avionics:
1- Vertical Power VP-X
2- Trutrak Digiflight II VSGV
3- Trutrak Autotrim
4- Pacote Advanced Flight Systems
a- AF-5600 Display x2
b- Engine Monitor Board
c- Engine Probes and Sensors AF-4CYL
d- AHRS Board
e- AF S Autopilot 2 axis with servos
f- AF-AOA
g- AF-BAT
h- AF-ARINC x2
That will be one heck of a panel. I'm a bit confused - sounds like you're getting all that you listed, which leads to a few questions.
All the above are covered by your AFS selections. Seems you don't need these?
3- Trutrak Autotrim
e- AFS Autopilot 2 axis with servos
Reads like you're getting two autopilots? Obviously you'd only be getting the AFS AP, eh?
Thank you! I hope it to be secure, functional and beautifull! It?s not cheap but it?s not possible to have everything!
I need the 1 to be TSO, as the brazilian flight regulatory agency demands, as with the Aspen, radio/nav/audio/transponder/cables.
The 4 and 7 would be used because of its quality, but I?m still checking its compatibility with the system and pricing.
The Westach ones will be used as backup in case of general EFISes failure.
And the AFS AP will not be part of the Advanced Flight Systems package (forgot to exclude it from the list!).
Cheers!
Cristiano
Status
