Rick, there is only one set of brackets to hold the bell crank that transfers the motion of the latch handle to the canopy latch pin on the left side. The bell crank is part of an assembly that includes a rod that has an arm on the right side that operates the canopy latch pin on the right side. I'm probably not describing it very well but you'll see when you get there.Hi Gang,
Sec 23-10, Figure One states: NOTE: There is only one set of C-01422 Canopy Latch Brackets.
Does this imply I can add a second latch on the right-side? If so, is there an upside to adding a second latch? Or was this a big head fake...?
Rick.
You mean section 29-10...They're telling you not to look for a second set because only one is required.Hi Gang,
Rick.
