RV3 Fuselage tank mod
navy06
Active Member
With leaking wing tanks slowly getting worse I have designed and installed a 18 gal fuselage tank. This is enough volume for my 0235 108hp powered RV3. By being smaller than Vans 24 gallon it doesn’t take up every inch of available space. My tank is round 20 inch diameter 12 inches deep. I added two 1/2 inch OD 1/4 inch ID aluminum thru tubes for anti-rotation support and as a back up support for the two stainless steel straps per vans drawing. It required minor adjustments to brake petals to clear and it would have been better to make tank 19 by 13 or 14. Will try to attack some photos.
FAA approved mod and gave me new air worthiness certificate and operating limitations. I have to fly 5 hours in phase 1 and have already flown 3 with no problems. I made screw held cover plates to replace wing tank fuel caps. The other photo is Usher Gascolater and new fuel lines. It is designed to be removed for cleaning at annual by removing cross bar holding it in place.
