gmcjetpilot
DXF file does not match panel in Kit? I could be reading the CAD file wrong?
I am reading the tape measurer right. CAD shows Approx 11.7" tall & panel is 10.7" tall. I am guessing the X means something. Drawing shows F-7103 no X.
Did Van change the size in height 1" in newer kits? (I know Van's store sells a 13" tall panel for customizing,)
Center Stack what did you do? Slider builders know in three positions at top there is structure that keeps items from being mounted too high up on the panel. I can work with it, just curious what you did? (tip up has different panel support)
- Move the stack to right?
- Modify stiffener to allow more clearance to stiffener?
- Lower top center instrument/radio to clear stiffener?
