Oil Quick Drain leak
Draker
My Saf-Air oil drain valve seems to have developed a leak. Does anyone with one of these know if it is user-servicable? O-ring?
Easily repaired with 3 o-rings. Assuming this is a Saf-Air P5000 drain valve (from looking at the picture, 1/2 NPT threads), it takes 2x MS28775-011, and 1x MS28775-012. Look here for more info:
Remove one retaining ring to open up the valve....change o-rings...re-assemble.
My Saf-Air oil train valve seems to have developed a leak. Does anyone with one of these know if it is user-servicable? O-ring?
Fumoto!
But, I've come to understand that for the 15yrs that I flew the RV9, every oil change included the whole tool cart for a full FWF inspection. I never took anything "quick" about an oil change. Lives other than my own depended on it. The RV8 just has a plug. It is my personal reminder to get out a wrench.
Yeah, I'll pile on the Fumoto recommendation. I have a Saf-Air on one airplane and Fumoto's on the other two. Never a drip from the Fumoto's but the Saf-Air has always dripped, and has dripped shortly after new o-rings were installed. It's going to be replaced with another Fumoto. I'm tired of the Saf-Air drips.
My quick drain which is same as yours, started leaking after 10 years. Got the replacement O-Rings at Ace Hardware and no more leaks.
