I see that the 650/750 take two power inputs and, unlike many other components, it is to provide more power and not simply redundancy.
I also see that one power connection is for the radio and the other is presumably for everything else.
Question: what happens if you put separate breakers on the two power inputs and then pull one of them, specifically the radio one? Will the 650/750 work normally (other than the radio) with only one power input?
