Hi all, from reading the forums, I've settled on I'm going to use Sherwin Williams P60G2 for anti-corrosion on the interior. (I have seen some of the debates about not applying anti-corrosion, but I'm going for it). And fortunately the local commercial SW store keeps this in stock. It was $180 my price with tax for a gallon of the wash and a gallon of the primer.
I don't think this has been asked; but if it has, I couldn't find it. So feel free to point me to the right link if you happen to know. Otherwise, here we go. My main question is, I've seen people recommend:
1. Deburr
2. Prep (Bon Ami + Gray Scotchbrite; then water flush, then dry with air hose)
3. Prime
4. Dimple
And it seems the main reason is the dimples shred the scotchbrite pads if you prep after dimpling.
I'm considering going with this approach instead:
1. Deburr
2. Prep
3. Dimple
4. Re-prep with acetone or lacquer thinner (to remove my greasy paw prints)
5. Prime
Would that end terribly bad? If not, then a follow-up question. The Prep with Bon Ami & Gray Scotchbright just removes oils and scuffs the surface, but doesn't remove the alclad protection. So, could I do steps 1-3, then set the thing aside until I have a batch of them, and do 4&5 say a week or a month later?
1. Deburr
3. Prime
4. Dimple
1. Deburr
2. Prep
3. Dimple
5. Prime
