Gosh, that stinks for that company. There don't seem to be a many competitors out there.
Do they make a "Y" adopter that I would plug into the back of my panel mounted King nav/com radio, that I could then put a short piece of flexible coax that would be quickly accessible (up under the dash, or wherever) to be able to plug whatever handheld radio I decide to purchase? Or is this even recommended?
Thx, DM
Exactly...if my current set up is bnc. I guess if isn't can adopt. Thx for taking out my leg work. I do appreciate it. DMNot 100% sure, but I think this is what you are looking for. I allows you to easliy plug a handheld into the aircraft's com anetnna.
http://www.aircraftspruce.com/catalog/avpages/icomswitchbox.php?clickkey=3576
If the only thing you didn't like was the way it turned on and off, would it me ok? I mean, I'd only be using it for emergency use. The A24 comes with things...the Sporty's unit does not. (accessory wise) I can scoop up the A24 from Marves for around 325 shipped, with charger and headset adpoter. I'm convinced...Vertex is NOT the way to go, per the man who owns the 710. Thx DMI will never purchase another handheld that you turn on and off by holding down a button. My old Sporty's A300 is what I grab when I need to use a hassle free radio quick....... and I have owned 6 different radios and one was the A-24..... hated it!! The on off button made me happily take a substantial loss just to get it out of my sight. It was well built and felt good in your hand, but........ ugh!
My choice for use and compatibility, though at $399 would be the latest Sporty's SP 400.
http://www.sportys.com/PilotShop/product/14807
Most likely is true, or some sort of malfunction. (not like cobbling up your tv antenna at home... ) That device as previously listed would be the correct way to go about it, I'm pretty sure. DMI have heard one person say you cannot just use a Y on an an antennae because it can back feed the other radio and blow it out.
Just something I heard. Never investigated further, so not a clue if it is true or not. Maybe the switch box mentioned earlier takes care of this?
Mark
I would use the supplied rubber antenna...but thought the reception was terrible...by other reports. I suppose better than nothing...and maybe just those folks and their timing. Would try it as is before trying to rig up anything else.Definitely if the output of a transmitter is connected directly to the input of a receiver due to some ill conceived coupling system you will destroy the receiver - possibly the transmitter as well.
What is required is some form of intelligence to actually switch and isolate each radio from the other - the Icom adapter might be the correct item but I say 'might' only because I have not investigated it in any depth.
One simple option is to provide an intermediate patch panel where the main antenna can be disconnected from the failed radio and connected directly to the handheld.
My preference is to not have this breakout and not have any unnecessary BNC plugs and sockets in the antenna feedline. Each connection is susceptible to failure, and is lossy (approx 0.3dB loss at each connection). If I ever do need the handheld in the air I will use the rubber duckie antenna supplied.
Vertex could also have the VOR built in, depending on model. I would have that feature for redunancy....at only another $50 on either model. So, if you were to do it over right now, which brand would you buy? (emergeny use only) Thx, DMI use an Icom and also a Yaesu and find them both about the same.
The Icom adaptor plug broke down and they are horrendously expensive for what they are. The Yaesu is harder to connect to an aerial as it has a screw in aerial rather than the bayonet of the Icom.
i use the Yaesu at the moment, but the Icom has VOR built in so it could be a better option, although a GPS negates the need for VOR.
