ianpatrick10
I'm New Here
Please contact me if you have an 0 360 A4A or A4M
Thanks!
Ian
Thanks!
Ian
I do have a NEW 0 360 A1A if you could make that work..... It's in PetalumaPlease contact me if you have an 0 360 A4A or A4M
Thanks!
Ian
Hi there, thanks but my mechanic says that won't work unfortunately.I do have a NEW 0 360 A1A if you could make that work..... It's in Petaluma
Yeah, I have a 1969 Cherokee 180D in need of a new engineThe A4A was built for Cherokee 180's around 1965. Same as the A3A except for the solid crank. Solid shaft variants were later used in certified Pitts S1S, later production Pitts used IO engines.
A4A for aerobatics is a false sense of security. Solid shaft engines flown agressively still had crank flange failures. Later engines had thicker crank flanges and those still had failures.
I can't think of any reason for needing an A4A except for replacement engine for Cherokee 180.
You may want to go back to your mechanic and see how the motor I offer above could work....Yeah, I have a 1969 Cherokee 180D in need of a new engine
I sent you a PM... Look for it in the envelope in the top right of your screen.How much are you selling it for? Freshly overhauled?
