28 days. Ugh.
My last RV flight was 28 days ago, but I fixed that Tuesday morning. The scheduling tumblers at the other two part time jobs allowed a quick trip out to the field for a tour of the area.
No pics in the air, just enjoying the scenery from 1,000’agl recharging the battery a bit. One pic on the ground.
Mental gyros realigned. I’m good for awhile…..;^)
dr
RE: Rocket style fuel tank vent
Thank you all for the concern about the potential for water to gather in the bottom of a loop. I then have to ask if you have concern that water could gather in the lowest point of a traditional installation And cause icing problems. Esp if there is less burping to potentially push water out.
dr
jcarne
I did something bad... Don't tell the wife... More to come later
bjdecker
OFF TOPIC:
dr
I decided to vent the fuel tanks rocket style instead of re-entry into the fuselage. The one thing I didn’t want to do was to put the exit in the wing root fairing so I went thru the wing spar and exited out the bottom skin. I also added a tiny hole on top of the line just before it exits in...
vansairforce.net
dr
WDYDWYRTW? 9/21-22/2024
...getting this weekend's thread started. v/r,dr *What did you do with your RV this weekend?
vansairforce.net
jcarne
RV-7A JCarne
Before commencing on the wheel pants (which will probably be a few months from now) I wanted to get to know the aircraft better before completing them. In the video below you can see as I slow down on the roll out the main gear shimmies a bit. (the rest of the video is just me taxiing) Not my...
vansairforce.net
bjdecker
G3X Touch - Oddity...
Hive Mind, A friend of mines G3X Touch began showing the blinking "O" on the CAS. Except, he doesn't have a Marker Beacon receiver installed (He has a GMA 245). This just "showed up" on a recent flight and persists...even in the hangar with the door closed. Running 9.51 software, No errors...
vansairforce.net
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
www.vansairforce.net
The VAF List ...a list of RV-related lists. RV-related things you might want to browse over (a closed post that is sticky and maintained by dr). Link to this in 'Links' in the menu. v/r,dr Small biz that brings you this page: 360 Avionics www.360Avionics.com Aircraft Extras...
vansairforce.net
