dr
HFS
Milestone …cgeyman
Engine delivered.
https://vansairforce.net/threads/engine-delivered.229838/
Data point …Vlad
Turbo I just clocked 6,250 TT on my RV9A. It took me 13 years to catch up on you.
Replacing remote oil filter with engine mount….Dan 57 reply
Here's the method I use, which of course is the best one around
The aviation tooling dept. of your nearest DIY outlet will provide you with a 2" plastic pipe... cut down to 3' and sliced in half, this will provide the perfect no-spill path for the oil to escape the slightly unscrewed oil filter.
No need to thanks me, saw this sometime ago on this forum
BrianP
nharris
Rv-12David
Johnwilcox
Cold Air Induction on a RV10
…Richard Connell reply
I’m a hinge guy, but the same thing would work with some tweaking for skybolts too.
https://vansairforce.net/threads/cold-air-induction-on-a-rv10.229831/post-1794287
OFF TOPIC:
WDYDWYRTW? 9/21-22/2024
...getting this weekend's thread started. v/r,dr *What did you do with your RV this weekend?
vansairforce.net
HFS
"Blind" ADEL Clamp ...
... Think blind pop rivet - can be "set" with access to one side only. Once in a while you have the need to install an ADEL clamp where there is no access on the bottom mounting flange to "wrench" on a nut. Such as the case for these shown below - they go on pushrod tubes (between cylinders)...
www.vansairforce.net
Milestone …cgeyman
Engine delivered.
Data point …Vlad
Passed The 4,000 hr mark today!!!!!!!!!
i knew it was coming soon but didnt know where i would be. the day started by flying to ft lauderdale executive airport as a flight of three RV6's. great vfr conditions, sebring was fogged in so fxe was the alternate. ron and bob are both fairly new to my airport and ron has latched on as my...
vansairforce.net
Good day fellow rvers. Next oil change thinking about removing the remote oil filter I have for a fixed one to engine. I notice the Casper labs one said prick a hole and the oil drains back to engine. I assume the same with the b and c which looks nice. But if I do this wouldn’t there be the...
vansairforce.net
BrianP
Trailing Edge MCS
I’m setting up to MCS the trailing edge holes. I set the MCS on a piece of scrap metal to flush plus 7 clicks. When I MCK in the VA-140, the MCK meet when done from both sides. I’m using the Cleveland base to keep the MCS parallel to the surface. Is this normal?
vansairforce.net
nharris
Wiring PTT to Mic jack
I'm doing an avionics upgrade on my plane, adding a Ray Allen G405 stick grip and a Garmin GTR205xR into a new G3X setup. My question is, how do I wire the PTT from the stick grip? the stick grip has one white wire designated PTT and a common ground wire.
vansairforce.net
Rv-12David
Empennage completion: attach everything and then disassemble for storage?
I've started to work on the tailcone. A completed empennage is not too far ahead! I assume it's a good idea to attach everything (without fully tightening the bolts) even if I need to disassemble the parts to save storage space. Is it what people usually do?
vansairforce.net
Johnwilcox
811 - longeron junction,
I have searched the plans and I’m sure I missed the instructions, or did I ? The junction where the Lingeron intersects 811, it appears it requires a bypass cut, either in the longeron or the stab attach bar. I’m thinking the Stab bar integrity is more important here, and the bypass slot...
vansairforce.net
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
The VAF List ...a list of RV-related lists. RV-related things you might want to browse over (a closed post that is sticky and maintained by dr). Link to this in 'Links' in the menu. v/r,dr Small biz that brings you this page: 360 Avionics www.360Avionics.com Aircraft Extras...
vansairforce.net
