petehowell
vansairforce.net
![Screenshot 2024-08-28 at 9.34.12 AM.png Screenshot 2024-08-28 at 9.34.12 AM.png](https://vansairforce.net/data/attachments/47/47873-775677b4a4543662ea175385eaa86287.jpg)
romaja
vansairforce.net
![Screenshot 2024-08-28 at 9.34.46 AM.png Screenshot 2024-08-28 at 9.34.46 AM.png](https://vansairforce.net/data/attachments/47/47872-ff31470a9340d1d6886577ffdc14b1ae.jpg)
Straight from Scott’s Brain
RE: AD-41H rivet installation
In cases where the proper nose piece isn’t available for the tool and you don’t have a huge number to do, make a small tool with a scrap of .063 thick aluminum. Use a drill index to drill a hole, just barely bigger than the diameter of the mandrel.
Use it as a spacer between the head of the rivet and the tool by first, slipping it over the stem before inserting the rivet in the tool.
Stems getting jammed in the tool is related to the tool not being properly adjusted.
The manual that usually comes with them explains what to do.
vansairforce.net
![Screenshot 2024-08-28 at 9.36.07 AM.png Screenshot 2024-08-28 at 9.36.07 AM.png](https://vansairforce.net/data/attachments/47/47871-16ba949ac5d8ecce698c289d3a149501.jpg)
From Dynon
![Screenshot 2024-08-28 at 9.37.09 AM.png Screenshot 2024-08-28 at 9.37.09 AM.png](https://vansairforce.net/data/attachments/47/47870-ffd8832a99d7c5388ef0b91175c9f698.jpg)
eastonale
vansairforce.net
![Screenshot 2024-08-28 at 2.08.16 PM.png Screenshot 2024-08-28 at 2.08.16 PM.png](https://vansairforce.net/data/attachments/47/47869-893cc856e525d2dd46abcb3f15dabd23.jpg)
OFF TOPIC:
![IMG_4676.JPG IMG_4676.JPG](https://vansairforce.net/data/attachments/47/47868-be211183d66e60927d4be55f4f2d301d.jpg)
Bonus Off Topic: (YOU'RE GOING TO LOVE THIS)...trust me.
x.com
www.vansairforce.net
vansairforce.net
North Fox Island
Andi, Gizmo, and I made it out to North Fox this weekend. We had beautiful weather and tailwinds in both directions, but the trip home got warm and bouncy. Big thanks to the RAF for opening and maintaining the strip - it is a lot of work! Get a brief before you go from the RAF website. We...
![vansairforce.net](https://vansairforce.net/data/assets/logo/vaf-icon-192x192.png)
romaja
Nose Wheel Fairing Bracket Help
Step one page 46A-11 instructs you to bend the nose wheel brackets as necessary to fit the inside surface of the wheel fairing rear. I have bent the brackets different ways to get them to touch the inside surface to no avail. I dont want to press the fiberglass fairing together as It will...
Is there a best method to use when pulling this type rivet that will produce a respectable outcome? I have about 1 out of 5 that resemble a decent finished rivet. The rest end up looking bad and they also plug up the rivetgun nosepiece to where you have to unscrew it and pound out the rivet...
From Dynon
Dynon Avionics | Pocket Panel | Portable EFIS
Dynon Avionics' Dynon Pocket Panels are true artificial horizon instruments based on the same technology that drives Dynon's Electronic Flight Instrument Systems (EFIS).
www.dynonavionics.com
eastonale
Help with Odd Vibration Needed
Hi Everyone, On my 3 yr old RV-10 I've been struggling to find the cause of a really weird vibration that comes on with higher power settings. It makes the control stick vibrate and I can feel it in the bottom of the seat and on the floor. After balancing the prop, changing engine mounts, and...
OFF TOPIC:
x.com
![x.com](/proxy.php?image=https%3A%2F%2Fabs.twimg.com%2Fresponsive-web%2Fclient-web%2Ficon-ios.77d25eba.png&hash=920a29d4a5153922400ab84d7a1b8f5e&return_error=1)
Doug's Area ....The VAF News & my flying resume.
![www.vansairforce.net](/proxy.php?image=https%3A%2F%2Fwww.vansairforce.net%2Fdata%2Fassets%2Flogo%2Fvaf-icon-192x192.png&hash=253ac26c64e15348dec9ea91bd1c9a3e&return_error=1)
The VAF List ...a list of RV-related lists. RV-related things you might want to browse over (a closed post that is sticky and maintained by dr). Link to this in 'Links' in the menu. v/r,dr Small biz that brings you this page: 360 Avionics www.360Avionics.com Aircraft Extras...
