SLO Mo 2 blade and 3 blade T/O:
…dr
I was out at the airport for about an hour Monday morning and a couple of airplanes were taking off as I pulled in. I put the little truck in park. Quality iffy but not bad for an iPhone from several hundred feet away being held in your hand.
vansairforce.net
![Screenshot 2024-08-26 at 12.20.53 PM.png Screenshot 2024-08-26 at 12.20.53 PM.png](https://vansairforce.net/data/attachments/47/47781-980bcc4c20229eb86e464188e28d4ee2.jpg)
Vapor Lock Update …Dan 57
Follow-up...
T stickers were installed on the gascolator, the EDP, and the carb bowl. 50 flight hours later the results are slightly surprising:
gascolator, no discolouration, looks like the fuel is running cool enough thru it
carburettor bowl, no discolouration, not sure of fuel really boiling if no hi T registered
EDP, there u go, hit the 154°C max mark
vansairforce.net
![Screenshot 2024-08-26 at 6.02.33 PM.png Screenshot 2024-08-26 at 6.02.33 PM.png](https://vansairforce.net/data/attachments/47/47780-9f36bfb1f18dc6ab7f78527a94830c7d.jpg)
RV-8 Status …Webb
Firewall forward is done. Windscreen glass starts tomorrow.
vansairforce.net
![Screenshot 2024-08-25 at 4.30.57 PM.png Screenshot 2024-08-25 at 4.30.57 PM.png](https://vansairforce.net/data/attachments/47/47779-b43b7cc311ba50877eac3c38f4cdb22a.jpg)
Desert Rat
vansairforce.net
![Screenshot 2024-08-26 at 4.10.49 PM.png Screenshot 2024-08-26 at 4.10.49 PM.png](https://vansairforce.net/data/attachments/47/47778-43c3ffb483b6fb338d782e26f566e0e9.jpg)
dmn056
vansairforce.net
![Screenshot 2024-08-26 at 4.12.56 PM.png Screenshot 2024-08-26 at 4.12.56 PM.png](https://vansairforce.net/data/attachments/47/47777-990406a4c2f782ae3e03fda2f678394d.jpg)
kirkbauer
vansairforce.net
![Screenshot 2024-08-26 at 6.01.05 PM.png Screenshot 2024-08-26 at 6.01.05 PM.png](https://vansairforce.net/data/attachments/47/47776-28181f0a43802a4d8157ca7095844218.jpg)
Ben Ellis Project Status Report
Finally got my wing top skins riveted on with the help of a friend. I was able to use the back rivet method and am very happy with how nice the rivets turned out.
vansairforce.net
![Screenshot 2024-08-26 at 4.09.58 PM.png Screenshot 2024-08-26 at 4.09.58 PM.png](https://vansairforce.net/data/attachments/47/47775-b7ef7928c86a9ab95c5daf1b2173dc15.jpg)
Ymc9
www.vansairforce.net
![Screenshot 2024-08-26 at 6.00.29 PM.png Screenshot 2024-08-26 at 6.00.29 PM.png](https://vansairforce.net/data/attachments/47/47774-27a051f810e49001cdce97087a3a9f58.jpg)
OFF TOPIC:
![Screenshot 2024-08-26 at 12.45.50 PM.png Screenshot 2024-08-26 at 12.45.50 PM.png](https://vansairforce.net/data/attachments/47/47773-75709f49ac24b4c2695d9fb48f0af0a6.jpg)
vansairforce.net
…dr
WDYDWYRTW? (8/24-25/2024).
What did you do with your RV this weekend? On an extra paper route Saturday KDAL-KCLL-KDAL - there was an RV-6A on the ramp as we taxied in! . Was gone when we got back from lunch. Was going to go out and look it over w/my captain. 1775 BBQ for lunch (first visit - FBO desk employee...
![vansairforce.net](https://vansairforce.net/data/assets/logo/vaf-icon-192x192.png)
Follow-up...
Would like to learn more on vapor lock
So I think I had vapor lock yesterday but wanted to hear others thoughts on the topic as well, since I wasn't anticipating it given the conditions (mainly the temp which I thought would generally need to be warmer to cause it). I'm flying an O-360A1A (carb) with 92 octane non-ethanol. I flew to...
RV-8 Status …Webb
Show us the status of your 8/8A project!
This is correct. My battery (EarthX) is on the firewall, I have an RV200 composite prop and the grove one piece gear. CG with me, wife, fuel and baggage will be right around 83”. Sorry all, I had a Homer Simpson moment (Doh!) :D Of course the CG will move rearward with fuel and people...
Desert Rat
EAA test Card 6. I need some clarity.
Hey guys. This is the test card that deals with stalls. According to the accompanying flight test manual, you fly each configuration 3 times to reduce variability, but you also fly it at 4 different weight/cg combos. This guidance doesn't seem to match up at all with the configuration...
dmn056
Aft battery ground resistance
I'm installing aft-mounted batteries. There seem to be alternative schools of thought as to whether to ground the battery negative to the fuselage nearby or to run a heavy ground wire forward to a firewall ground. My fuselage components are fully epoxy primed, so I wondered if there would be a...
kirkbauer
Under-compartment for baggage area
I want to put a compartment under the baggage area for tools -- that way I always have them with me but they aren't in the way. My plan is to put it between the left tunnel rib and the next rib towards the baggage door. Here is the area (note that this shows the right floor panel but I'd be...
Ymc9
Torque wrench needed for phillips head screws?
The forward skin is attached to the V stabilizer with AN5 philips head screws. Do you use a torque wrench to fasten them? I tried it a bit but felt it quite difficult to hold a screwdriver bit tightly with a wrench. Also, if a torque wrench is to be used, what torque value should be used for...
![www.vansairforce.net](/proxy.php?image=https%3A%2F%2Fwww.vansairforce.net%2Fdata%2Fassets%2Flogo%2Fvaf-icon-192x192.png&hash=253ac26c64e15348dec9ea91bd1c9a3e&return_error=1)
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
The VAF List ...a list of RV-related lists. RV-related things you might want to browse over (a closed post that is sticky and maintained by dr). Link to this in 'Links' in the menu. v/r,dr Small biz that brings you this page: 360 Avionics www.360Avionics.com Aircraft Extras...
