Rosie said:I'm studying for the written and just read there are some approaches that require a second VOR.
I'm installing an SL-30 that has the capability to monitor the standby VOR radial.
Can the standby VOR be used as the second VOR receiver for this type of approach?
mikeljshields said:I have the SL30, when you select the second nav you get the bearing from the second VOR you have dialed in on the front of the SL30 panel, when flying an approach that uses a VOR radial to denote a fix, once you see the cross bearing required your there! It actually works very well.
