I really want the 5-point harness -- BUT, my wife is not real thrilled with the crotch strap. I seem to recall reading somewhere that if the crotch strap is installed, it must be used (i.e., the 5-point harness doesn't work well or at all with only 4 points connected.) However, I also seem to remember reading that with the rotary connector, each segment snaps in independently, which seems to imply that you could use it without the crotch strap connected. Of course, it might not be effective with only 4 of the straps connected, but I don't know. I'm sure somebody out there on this forum has the wisdom/experience to answer this question.
yes, i've thought about 5 on the left and 4 on the right, but i don't really like that solution either.
