I love that chart and have been using it for years. So easy to use and works great.
Of course, you will have to take field altitude AND density altitude into consideration. It goes without saying that aircraft performance is different from airplane to airplane depending on many factors. The charts will give you a vague idea of what you might expect but getting out there is the best way to find out what the differences will be.I haven’t found a chart for this. Is this something no one has done or calculated? my desire to fly into Salida CO prompted this—7,500’. In my case its an 8A with o-360 constant speed prop. Thanks!
As an FYI ...I haven’t found a chart for this. Is this something no one has done or calculated? my desire to fly into Salida CO prompted this—7,500’. In my case its an 8A with o-360 constant speed prop. Thanks!
It also helps to go to a mountain flying course. I loved the Colorado Pilots Association mountain flying course. It was a great experience and learned a lot with a day of ground and a day of flying in the Rockys with my airplane.In addition to the above cautions - if you have spent your whole life taking off from near-sea-level, make sure that your LEAN for best power before takeoff, or you’ll be giving away gobs of horsepower….
Pre-takeoff (and landing) checklists shouldn’t - IMHO - say “full rich” for mixture … they should say “as appropriate”.
