I put my SafeAir quick drain at the left front location (see #6 in attached).
No you do not need to lift the tail. My -14 drain is in the same location as the Vans demonstrator. Rear of the engine. Somewhere here on VAF you can find a picture I posted.
Yes it is......
This was taken looking up through the lower cowl exit. The quick drain is on the left side, under the fuel pump. The suction screen is on the right.
