grjtucson
I'm building an RV-7 and want to solo from either seat, but mostly from the right. Hear are my thoughts/decisions so far:
- dual brakes
- center mount throttle/mixture/prop/flap switch/elev trim switch
- PTT on each stick but nothing else
- center mounted manual aileron trim
For the panel, I'm thinking of dual GRT's, one centered on each seat, with airspeed, altimeter, a Lift Reserve Indicator, and a Tru-Trak ADI Pilot II as backups centered over the radio stack.
I've searched the forums and the web and haven't come up with much. Does anyone have any thoughts, things I should look out for or be concerned with, etc.?
Finally, does anyone know if I can get my right and left sticks swapped so the left is the removable one and the right is fixed, or even better, so they are both removable?
Thanks in advance,
George
- dual brakes
Thanks in advance,
George
