Howdy all,
I'm still debating the build decision. Primarily I'm concerned about the noise of riveting. I just am not a big fan of noise. Fir instance, when I build furniture I mostly use hand tools. I'm curious if the noise is going to drive me out of the garage. How much construction time is noisy? I've also been considering the Zodiac due to the pop rivet construction method. Any thoughts?
Also, I'm most likely not going to have a building partner readily available to help buck rivets. Will this be an issue?
Kevin
Kevin
