Clayton,
I just ordered my firewall forward kit for an RV-8. I am using an XP IO-360 nearly identical to yours except I have two mags.
Here is the actual contents of the standard kit (for a lyc 180 hp IO-360):
FF-8 IO-360M1B C/S FIREWALL FORWARD KIT
2.000 CT Q-60 QUADRANT CABLE 60"
1.000 CT Q-55 QUADRANT CABLE 55"
1.000 FAB-HORIZ INDUCTIO IO-360 180/200 HP
1.000 IO-360 THROTTLE/MI CABLE ATTACH KIT
1.000 PLASTIC TIE WRAP 5 NYLON TIE 70-0108
1.000 VA-136 FUEL LINE IO-360 23"
1.000 PROP GOV MT P-860- (I)O-320/360 LYCOMING
1.000 VA-183-PC MT GOV CABLE BRACKET
1.000 BAF-6-360 COWL BAF 6/7/8
1.000 VENT DL-05 1 3/4 EXH HEAT MUFF
1.000 VA-139 FUEL SUPPLY HOSE 16.5
1.000 AA6-063X3/4X3/4X9" ALUM ANGLE
F.WALL FWD COM M1B 8 ------SUB-KIT--------
1.000 AT0-028X3/16X6 FOR F.WALL KIT
1.000 AT6-058X5/16X15 7/ ALUM TUBE C-610
2.000 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!!
1.000 FF 3/4 FIREWALL PL SS FIREWALL PLUG
1.000 EA LV-1 HEAT SHIEL EXHAUST HEAT SHIELD
2.000 CT A-740 BLACK PUSH PULL CABLE BLACK
1.000 DUCT CBT-5/8 COOLING BLAST TUBE
1.000 EA CV HOSE 9816 BREATHER HOSE 4 CYL
1.000 EA DYNA BOLT BOLT SET 4 CYL DYNAFL
4.000 EA DYNA VI-STD VIBRATION ISOLATOR
1.000 EA EXH 8 IO-360M RV-8 180HP EXHAUST
1.000 EA OIL COOLER II O-320/360 OIL COOLER
1.000 ES 24021 STARTER SOLENOID 2OUT
1.000 ES 24115 MASTER RELAY
1.000 ES ALTERNATOR 60A ALTERNATOR & BOSS MNT
1.000 ES WH-8 FWD HARNESS, FWD BATTERY
1.000 FF-705 BREATHER TUBE
1.000 FF-709 OIL COOLER DOUBLER
1.000 IE VMP INSTALL KIT FITTINGS/HOSES
1.000 PT-035X1/4X12 FUEL OVERFLOW TUBE
1.000 VA-102 FUEL PRES. HOSE 15.5
1.000 VA-168 SENDER MOUNT
1.000 VA-133 OIL PRESS. HOSE 27.25
1.000 VA-134 OIL COOLER HOSE 19.0
1.000 VA-135 OIL COOLER HOSE 16.5
1.000 VENT DL-03 2" ALUM FLANGE
1.000 VENT SCAT 2X6' SCAT TUBE X 6 FT
1.000 VENT TG-10 CABIN HEAT SELECTOR
1.000 AS3-063X1 1/2X4 6A--8/8A (INCHES)
1.000 AT0-035X3/8X24 SOFT ALUM TUBE
0.500 F AE102-11 FIRESLEEVE $/FT
0.250 EA HOSE H177 IO SNIFFLE HOSE $/FT
1.000 BAG 626-1 FF MISC. HDWRE IO-360
1.000 BAG 627-1 FF MISC. HDWRE IO-360
1.000 BAG 628 FF MISC. HDWRE IO-360
1.000 BAG 629 FF MISC. HDWRE IO-360
1.000 BAG 958 AN426AD3-4 RIVETS
1.000 BAG 991 AN426AD3-3.5
1.000 BAG 1934 AN426AD3-5
1.000 BAG 1935 AN426AD3-6
1.000 BAG 1978 AN470AD4-5
1.000 BAG 1979 AN470AD4-4
1.000 AS3-063X1X12 ALUM STRIP
1.000 CT BEARING HWR, PR BOLT, NUT, WASHERS
1.000 CT BEARING MW-3M THROTTLE ATTACH ASSEM
1.000 DOC FWF COMPLETE TEXT/DWGS
From what I have been told, the only required change is replacement of the standard exhaust with the special Superior exhaust. I also substituted the plane power alternator for the standard alternator.
After I get the installation done I will let you know how it all worked out!
Pat
