Has anyone had this problem with the aux audio input on their ICOM A210 radio?
When the auxiliary input is enabled, I hear a noise similar to an unsquelched receiver (white noise) in my headset. This is when the ?AUX IN? config item is set to ?ON? or ?INCOM?. If ?AUX IN? is set to ?OFF?, I don?t hear the noise. This noise is present when nothing is connected to the ?Auxiliary audio 1/2/3? pins. The noise is also present if I short the pins to the ?Auxiliary audio minus? pin ? seems to make no difference what is connected. The noise does not change its volume as I change the ?AUX LEVEL? from 001 to 080. The noise goes away if I set ?AUX LEVEL? to ?OFF?. If I set ?AUX LEVEL? to ?AF GAIN?, the noise does not increase/decrease with the volume knob unless it is fully CCW at which time the noise is extinguished. Setting ?ANL? to ?ON? causes the noise to be reduced just slightly. The auxiliary inputs seem to work when I inject a properly attenuated audio alarm signal from my Dynon D180 EFIS. The noise is present when the EFIS alarm is OFF (and drowned out when the alarm is ON). I have had everything else powered down in the aircraft. This issue has been present since I bought the radio as I had the issue when I connected just the radio and headphones on at my workbench. I don?t think this is some kind of ground loop problem on the aux input since it's there no mater what the condition of those connections. I don't think it is a ground loop on the audio headset side or it would be regardless of wether the aux input is enabled. Normal receiver audio, sidetone, and intercom seem to be fine.
