I think it's pretty safe to say that EVERY major paint manufacturer is going to tell you to only use a specific primer.
I've used lots of different primers over the years and Mil-prf-23377 primers definitely offer good adhesion. I've used lots of Boeing BMS-10-11 with very good results and it is water based catalyzed epoxy primer and I have never had adhesion issues.
Some of this is what you can get your hands on in your part of the world. . Just be sure that whatever you choose to use, you run some test panels....and test it. Tape Adhesion test is easy...wiat for it to cure for 3 or 4 days, put down a 6 inch strip of good solid masking tape or I use nylon strapping tap...rub it on...and RIP it off....see how good your adhesion really is.
I think surface prep is very important. technique can also be important and temperature and humidity very much so...
Hope that's helpful,
Steve.
