I have been using S-W P60 for most of my priming. However, there are times when I just want to prime a couple of small parts, not worth using the gun, so I bought some SEM rattle can primer.
I had great results with it till recently.
I m working on the roll over structure and primed the 4 pieces of F-01341, roll bar frame.
I t looked ok till the next day when the primer all flaked. I did the same prep I do on everything - scuff with fine scotch brite (gray), wipe with a degreaser (SX330 Acrli-Clean), let dry, prime.
So, then I wiped it down with Laquer thinner constantly changing cloth and removed all the primer. Then I wiped it down again the the SX330. Dried it very well, Prime.
Most 2 of the 4 pieces were ok, but 2 still had a little flaking, and I could scratch it off with my fingernail. I read a previous thread about this and thought I had it covered.
What's going on? Those frames seem like a different material?
