ChiefPilot
I found today that plugging in the mic cable on the copilot side to my PS Engineering PM3000 intercom results in odd behavior. Specifically, the pilot mic is blocked, and the xmit led which is normally either red or green turns orange. Without the copilot mic plugged in, things works normally.
I've checked the wiring but it tests ok with an ohmmeter. I see good continuity between pin 3 on the db25 connector and the plug center conductor, as well as ground between pin 1 on the db25 and the plug barrel/ring. PTT isn't used, and there is not a short between things.
Again, this only happens when a headset is plugged in (I've tried three different ones). I'm starting to think it might be the PM3000 - I'm wondering if the orange LED indicates a problem.
