tailcreek_flyer
Active Member
I am in the process of building my PAR100EX wiring harness. Its a pretty simple install with pilot and co-pilot headsets and the supplied R760 transceiver on COM2. I intend to connect other input sources for music at a later date but would like to install the wiring in the harness now. This also applies for my COM1, primary transceiver which will be installed once I start to make miles in my RV9A.
How should I handle these open ended inputs to the PAR100EX system? Will it suffice to leave them coiled and tagged behind the panel or should I wait until I am ready and then add them to the harness as required (least desireable option)? I would think that if the shields are installed as specified and the conductor pairs are isolated, I should be OK.
Cam Andres
RV9A with Aerosport IO360
Building log
www.tailcreek.com/tcaviate
Cam Andres
Building log
