Anyone thought about or done a oil cooler heater in the cabin? something like putting some bulkhead fittings on the fire wall and use a fan to blow through the cooler to extract the heat. I wonder what the change in temp would be, I would think you could run two coolers, one for engine cooling fwd of the firewall and have a adjustable valve to close it during cold weather and the one in the cabin would be used for the heat extraction. I supppose getting the oil hot enough to make this work may be a problem in the winter.
anyone with any input, data, ect. ?
I thought about this a few months ago and I see someone asked the same question in another thread so here it is.
