I need some help with my radio noise from someone who may know what I should do.
Handheld with rubber antenna works wonderful for the last three years with no noise at all, I installed a real antenna on the belly of My RV-3 just forward of the spar. Now every time I use the electric fuel pump or the electric flaps, the noise in the radio is so loud that I want to remove the headset.
I have no wires running with the antenna coax, no noise filters (not sure what to get) the antenna has no BNC connector on the antenna, just a wire end connection and ground. Antenna is 6 inches from the fuel pump and 3 feet from the flap motor.
Any and all advice is welcome and appreciated.
Thanks in advance
Perry
Thanks in advance
Perry
