I'm looking to order my Firewall Forward kit (vernier) from Van's. I have a standard IO540 on the way with dual pMags. What items should I delete from the kit? Here is what I have so far:
- Delete the alternator (I'll be using B&C and Monkworks)
- Delete the starter/master relays (I have other ones planned)
- Delete the throttle/prop/mixture knobs/cables (I'll be using an Aerosport panel which I believe will require longer cables)
- What about manifold pressure? There are a few items in the kit related to that, and as I understand it I may need something different for the pMags?
