Has anyone wired up a Monkworkz generator with a vertical power unit?
This is what I'm thinking from reading the manuals but really not sure.
- Connect the Generator to the regulator as specified in the manual.
- Run Output Power (10 AWG wire) to the switched side of the battery contactor with a 40amp fuse between.
- Regulator output ground (10 AWG wire) to aircraft ground
- "Enable" pin 1 from Molex connector on regulator to Alt pin J12/11 on VPX
- "Ground" pin 6 from Molex connector on regulator to aircraft ground
- program a switch to activate Pin j12/11 on VPX - to enable the Gen
And hopefully, that works.
Any insight would be appreciated.
