Guys,
I could use some help with this radio.
I replaced an old 2 1/4 radio that had no intercom with a new MGL v6.
So far it is not working well at all.
Had no transmit / receive issues with the old dittel radio.
Put together a new harness for the stereo headphone and mic jacks.
On the ground trying to adjust the mic's in accordance with the manual I had to turn the mic all the way down for my LightSpeed Zulu 2, -12db.
Anything less and it seems to way overdrive the intercom.
Started out with the default vogad med, level 2 and boy is that not work at all once the engine is up to power and you are in flight.
Had vogad high level 8 and enable the bandpass mic filter to get it to quite down in flight.
The tower could barely make out my transmissions in flight, but once on the ground they could here me ok.
Was hoping someone has had some better luck with this radio, cause as it stands now the thing is useless.
Tried to call MGL but have not been able to get anybody there to talk to me
Thanks for any info.
Chris Olsen
N2ZK RV-4 @ KAEG
Chris Olsen
N2ZK RV-4 @ KAEG
