You may not be familiar with the Harmon Rocket II build sequence; but, the F-404 (Rocket) bulkhead is undrilled, and it is your job as builder to (somehow) set the wing spar dihedral & butt joint wrt the forward/aft bulkhead faces, and drill/ream same. A bit more complex than having a match drilled parts set. (Way) old school.
HFS
HR2 S/N 002
Talk with Wayne at Phlogiston. He may be able to help.
I am building a HRII and just started the center section. Trying to figure out the best way to match drill the already drilled spars and W-420 spar splice plates to the center section F-404's. Open to hearing all suggestions.
Wayne has retired and closed his shop. Sold the equipment too, unless I'm mistaken. Probably at least 18 months ago.
